Trade: Plumbing
Confused Master Plumber
I have a cabin in northern Mi (if that matters) and plumbed 1000's of houses and never had this issue, whenever the weather changes i can be outside my cabin and smell the sewer gas come down from the roof. Has anyone else ever had this problem and how do i fix it??
#2 | |
Professional Instigator
Re: Confused Master PlumberQuote:
#3 | |
Pro Plumber
Trade: Plumber
#4 | |
Proud Plumber
Trade: Plumbing/Building Contractor
Is the sewer or septic exiting the building near where you smell it, hence a clean out plug not properly tightened and releasing gas or missing. Hope this helps---
Bill "I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett |
#5 | |
Proud Plumber
![]() ![]() Luke I am your plumber, say it outloud into a fan and it sounds like the real deal.
I am thinking by now the scent got to bad for him to bear and he called a real plumber out. May using the darth varder voice if he needed too
Trade: carpenter/ handyman
Maybe a P-trap ran dry? My sister had an odor inside & outside her house. The neighbors were starting to complain. It turned out to be a never used wet bar sink in a closet. She ran water for a couple of minutes & the problem never came back.
Steve |
Trade: Plumbing
I have to laugh @ the responses, I am a second generation master plumber with an electrical engineering degree, I'm not a disguised homeowner, dried up trap or loose clean out?? No neither, plumbed the cabin myself and it is a heated slab with a septic but depending which way the wind is blowing you can smell it on that side of the place, it is a single story 4/12 pitch roof with 18" riser out of roof, you can NEVER smell it inside the cabin only outside and it's not constant, wind blows u smell. I am however in the tallest (elevation wise) area in Michigan, when it snows we get Appx 2 more inches than anyone else, so i think the air comes across the flats and compresses where i'm at and forces the gases down?? I'm just hoping some one from a mountanous area would know a solution, I've talked to other people in the area, builders etc., and they said the same thing. By the way before you rip, i know bad sp? in a hurry have to go thanks
#9 | |
#10 | |
Handle It!
Or is it better know as a "Fart Filter"?
Pro Plumber
Trade: Plumber
Re: Confused Master Plumber |
Ron, the vent came out the roof and was WELL away from the doors and windows. The issue actually wasn't stink in the house, it was stink in the back yard on certain days when the wind was just right.
How remote is this cabin? Did you forget about the body you dumped out there?
Trade: Plumbing & Gas Contractor
Maybe a back-check valve installed where the bldg. drain and bldg. sewer connect will stop the gases,of course if your getting negative pressure it may suck your traps dry.
One of our customers with
septic tank had this problem in a really bad way. His plumber put in a whole house trap with a clean out where the waste line exited the house. 'Twas the septic tank cooking off maliferous aromas. Problem remains solved.
#16 | |
I've never installed an exterior trap but I know it's legal at the connection of a combined sewer/storm-water connection on the storm-water side,if it's legal in the area to run san. and storm together. I would have to speak to a local inspector to get their opinion on the building-drain/sewer trap. |
#17 | |
before, and I think the consensus seemed to be positive.
#18 |
Trade: Plumbing
Alot of good answers, going up this weekend will try one, i like the whole house trap idea but i think i'll wait till summer, already have 3" of snow, so charcoal filter will be first attempt.
#19 |
Trade: Plumber/Gasfitter
When was the last time you had you septic tank pumped out. Sounds like the tank may be dead.
#20 | |
Certified Remodeler
Trade: Kitchen bath remodeler
Vote for Pedro Kitchen, bath, St Paul remodeling Minneapolis Remodel Blog 203K Loan Consultant Minnesota |
| Alabama Master Plumbing Exam | plumbcrazy | Plumbing | 2 | 10-09-2008 07:32 PM |
| Need Master plumber for sponsorship in TX | Making money | Plumbing | 4 | 05-09-2008 10:25 PM |
| What floor would you put the master on? | wackman | General Discussion | 10 | 02-02-2008 03:38 AM |
