Condesating Steam Pipe
Old 04-26-2009, 08:20 PM   #1
Platinum8's Avatar
Trade: Finish carpentry and Painting
Hey guys,
I would assume this is a question for some plumbers or anyone with any knowledge about this. I have a customer who has old steam radiators in his home. There is a pipe running up from the basement thru the first floor to the second floor.
The pipe had a lot of condesation on it so bad the all the paint on the wall and ceiling is peeling extremely bad. The pipe is about 2-3 inches off the wall. I want to find a solution to the problem before I do any work.
The work he wants done is to fix the wall and ceiling. scrape, patch, sand and paint. then he wants me box in the pipe so it doesn't happen to the wall again.
I am worried about it still condesating and just dripping down onto the floor and ruing that and potentially rotting the subfloor. There is about a 3/8" radius around the pipe in the floor going to the basement. I am just looking for some solutions I guess to solve the condesating problem, which by the way was pretty bad in the winter because thats when I noticed it.
Thanks so much guys,
Deano
Platinum8 is offline
Old 04-26-2009, 09:06 PM   #2
K2's Avatar
Re: Condesating Steam Pipe
Are you sure it's not leaking steam?? I have a steam system and have never had condensate outside the pipes. I have had a little leaking here and there.
K2 is offline
Old 04-26-2009, 09:31 PM   #3
Moderator
Double-A's Avatar
In order for water vapor to condense, the surface its condensing on must be cooler than the air temp. If this is a pipe that serves a radiant heat system, then its not going to have condensation on it.
New York Times, July 20, 2006
Double-A is offline
Old 04-26-2009, 11:16 PM   #4
K2's Avatar
So then we could have leaking steam turning to condensate or leaking condensate.
I've found that resi steam pipe leaks are generally minimal at 3-5 psi and in my climate a little steam out into the living space is usually welcome. Also found that steam leaks tend to seal themselves over time if they are not getting banged around.
K2 is offline
Old 04-27-2009, 08:25 AM   #5
K2's Avatar
Call a "wet head"... Plumbers around here don't know jack about steam but they will take your money.
K2 is offline
Old 04-27-2009, 08:57 AM   #6
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
its a heating question, not a plumbing one. internal steam pressure for a residential boiler is approx. .5 psi, yes a half-a- pound normal. the problem doesnt sound like moisture condensing of the pipe but rather on the wall. i'm assuming its an exterior wall that's colder in the winter, reguardless, i'd first check for slight leaks around any fitting and seal them. then the pipe should be insulated with a good fiberglass wrap with vapor barrier (overkill) to midigate the temp difference associated with moisture accumulation. the one could box it out.
NickTech is offline
Old 04-27-2009, 08:29 PM   #7
Aframe's Avatar
Trade: Carpenter/GC
Platinum
have you gone upstairs yet
http://www.contractortalk.com/f11/pe...nt-pipe-51208/
Aframe is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
chimney pipe extension trade HVAC 5 04-02-2009 12:47 PM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
Very clean galvanized pipe. silvertree Plumbing 14 09-14-2008 03:47 PM
Romex to Steam Pipe clearance? K2 Electrical 3 02-22-2007 10:01 PM
