Condensing Oil Fired Boiler
Old 02-13-2012, 08:39 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,958
Is there anything out there yet that is a good reliable unit. I've got to make a choice on a boiler soon. It's either propane or oil. Everyone I've talked to says the oil technology just isn't here yet. But the price of propane is scary. Also, maintenance costs are a factor to consider. Only looking at condensing units? Any thoughts? Thanks, Nick.
Morning Wood is online now
Old 02-14-2012, 06:42 PM   #2
Box Builder
Re: Condensing Oil Fired Boiler
Wow. No one. Should I try to HVAC section?
Old 03-01-2012, 03:01 PM   #3
Jackfre's Avatar
Trade: General, plumbing, HVAC, solar
Back in the mid-80's I represented a company which made a condensing oil furnace. Ultimately, it put them out of business. To bad, as they were good folks, but they put the product out to general sales rather than strict certification of the installers prior to buying.
Net/net the service requirement is just to great. Savings are eaten up by component failure and cleaning costs. Ph of the condensate is in the 2.6 range vs gas' 3.1.
IMHO, your best bet is to buy a large lp tank rather than have the company supply a smaller tank. That lets you get over the heating season, depending upon your heat loads, and not have to be buying mid-season. I'm starting a remodel soon and will be installing a 1000 gallon tank to replace my current 250.
Oil has 140ktu/gal where lp has 92kbtu. On the face of it, oil would win, but 100 times out of 100 I would go with a gas fired modcon boiler with a good outdoor reset system and be done with it. You will gain about 10-12% efficiency gain over the oil unit and the benefit of modulation will save you about 30% and make you more comfortable.
The real issue with oil is that it is kind of a boutique fuel. 80% of the oil sold for residential heating is in the greater northeast. Major manuf look at development costs of a product and say, "Gee, I can spend X$ developing a new high efficiency gas unit or heat pump that will sell all over the country or I can spend the same X$ on an oil fired unit I can sell in the northeast". The product development costs do not work out.
There are other things you can add to your home to reduce your overall heating bill, minimize oil consumption and save money. is your current oil boiler in decent condition?
Jackfre is offline
Old 03-01-2012, 04:09 PM   #4
Box Builder
I am adding an 2k square ft addition to my house and gutting the existing 1k square ft house. Existing boiler is going bye bye. Burnham with beckett burner. it is probably from the 80's. 3k square ft total when all said and done. Peak design load is about 50k btu's for the house. Double wall construction, lots of insulation everywhere, lots of attention to air sealing, air recovery unit, etc. Defintely going wall mounted modulating condensing boiler. Was decided on the Buderus GB142, but thought I might consider oil one more time or a different gas fired manufacturer like triangle tube. The buderus comes with the manifold already assembled so there is quite a bit of savings right there.
Old 03-01-2012, 11:52 PM   #5
Jackfre's Avatar
Buderus is a good unit as is the Triangle Tube. I would put the Rinnai against either of them. It too comes with the low loss header and is a SS hx. I'm biased as I represented them in New England for 21 yrs. I would suggest you look into mini-split heat pumps for cooling and dehu. Don't oversize them in Cape Ann (lovely area) as you will need dehu more than cooling there. What is your distribution system?
Jackfre is offline
Old 03-02-2012, 08:25 AM   #6
Box Builder
Radiant hydronic in living spaces. Baseboard in bedrooms. We are seriously considering Mitsubishi mini splits, which may get rid of baseboard in the bedrooms. Putting in the smallest head units possible. I think we only require like a 2 ton system which is impossible to accomplish with the floor plan. They will be used mostly for ac and dehumidifying, but may be used for heat too if the radiant can't jump back quick enough on warm sunny days. I will look at the Rinnai and ask my plumber about it.
Old 03-02-2012, 12:28 PM   #7
Jackfre's Avatar
Again, my bias is noted as I represented them for 12 yrs in New England.
What I did with the mini-splits was to put a multi unit in the bedrooms and put the highest efficiency 12 (25 seer/12hspf) unit in the primary living area. I run the ms downstairs with my Rinnai Energysaver to heat the first floor. The upstairs unit hardly ever run.
It is a good idea to have alternate heat in conjunction with your radiant. The lead/lag issues with radiant mean it is best when the system has a load against it, even with the most precisely programmed ODR system. In Sept, most of Oct and even into Nov as well as April, may early June you will not want to run the boiler but will have no problem running the ms
Last edited by Jackfre; 03-02-2012 at 12:29 PM. Reason: my title window did not show in the post. i said, check out Fujitsu too
Jackfre is offline
Old 03-04-2012, 09:05 AM   #8
Box Builder
The way the house is laid out we will have two outdoor condensers. One will run our master and main living space and the other will end up running one of those small ducted head units and probably another small unit for the rest of the downstairs. Not ideal, but the way it has to be. I looked at the Rinnai, and it doesn't seem to modulate down very far on propane. Everywhere is granite and ledge, so burying a tank is going to be costly, but I like the idea of owning a tank.
Old 03-05-2012, 09:14 AM   #9
Jackfre's Avatar
In MA I believe the max oil storage is two 330 gallon tanks. I was on the NFPA 31 Committee for about 15 yrs and there was discussion of allowing double that, but check with your local ahj and your oil supplier. If I was going to have a lot of storage of #2 I'd build a bunker to hold it in the event of a leak. If you decide to go oil, just get a Buderus and a Riello cast iron and service it properly and you will hit the low to mid 80's. Drop an indirect off the boiler and you will be set. Get the best ODR unit you can. Buderus has their own. Pricey, but worth it. Run your mini-splits as much as you can and you can get 80% of our heating with them. Again, I would try to put the bedrooms on one multi. Line set lengths are quite liberal. Try to lay it out that way. The multi's are not as efficient as the single heads. Make sure you use the Air-Tec wall mounting brackets to support the condensers. You want them way off the ground.
Jackfre is offline
Old 03-07-2012, 03:13 PM   #10
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 232
http://www.viessmann.com/com/en/prod...d_boilers.html
I have a natural gas Viessman condensing boiler... Easy setup, works great... It was a bit warmer this winter, but my gas usage was 35% lower than last year. (avg 9 degree difference last year to this year)
Splinter is offline
Converting boiler from Gas to Oil ( Burnham V70w3 Boiler) rnrjvj HVAC 3 12-13-2011 08:35 PM
Manual operation of gas boiler (baseboard heat) Need help CarrPainting HVAC 5 11-27-2011 10:26 PM
condensing boiler water heater combo unit builditright Plumbing 1 02-10-2011 08:05 PM
Munchkin Boiler heat & domestic BoulderBuilder Plumbing 14 12-02-2009 05:34 PM
rotten egg/sulfur smell from oil fired boiler ApgarNJ HVAC 2 01-20-2009 05:15 PM
