Concrete Septic Tank Lifespan
Old 02-04-2018, 05:36 PM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,226
Can I get some education on concrete septic tanks, particularly in the PNW? Do they last longer than steel? When the leach field goes, can the tank often be reused? Looking at a 45 year old house. Surely things are near the end of the lifespan.
Golden view is offline
Old 02-06-2018, 03:04 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 94
Re: Concrete Septic Tank Lifespan
Dang, helpful forum, huh?
What I know from my limited experience, is there is no reason why a concrete tank can't last 100 years or more. As long as it doesn't crack, and the baffles are not damaged.
Far more often, the leach field becomes saturated, and no longer functions as efficiently, or at all.
An inspection by a septic specialist is invaluable.
Delta
I have an Edifice Complex.
Golden view (02-06-2018)
Old 02-06-2018, 06:14 PM   #3
edward trowelhands
Trade: Diplomat
Delta
My experience with leach fields as well. I only saw steel tanks in Alaska, but think it was for strength since they buried them 6-8 feet.
Old 02-06-2018, 08:49 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 882
On my dads farm we poured one with a skip mixer back in the 70s and it is still work fine today. A bought one should last a long time seeing how the concrete is poured pretty strong in order to be water tight.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
Fouthgeneration (02-07-2018), Golden view (02-06-2018)
Old 02-07-2018, 05:18 AM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,219
The tank should last centuries if not subject to frost or super wacky ph levels....concrete lined aqueducts are still carrying water in Italy....
Have the seller pump the sludge out and get a video of the grease trap, vault and flow divider box...
A surveyor could check the inverts of the sewer lines and grease box intake, if there is a chance of a faulty install.
If the leach field is infiltrated with fines, just dig new branches 3' to one side of the old branches, use synthetic geo cloth that won't rot over the washed septic rock or the new style tunnel arches. add air turn out/ups to increase capacity at far ends of the leach field runs also a field tile installed ran to day light,drainage ditch, water shed, or storm sewer, about 50 feet away "up hill" surface grade but actually below the depth of the leach field will keep the leach field above the local water table in the wet seasons/years, long term, septic action, anaerobic in the vault, aerobic bacteria action in the lateral leach field lines/rock beds
Fouthgeneration is online now
Old 02-07-2018, 05:32 AM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,488
Tank is the cheap part.
The system on this old place started failing. Rules changed over the years. Had to be an elevated field, had to reuse the dirt (no hauling off), had to be a new tank (from 600 gal to 1200 gal), etc.
Bottom line, 18.5K
SmallTownGuy is online now
Old 02-07-2018, 05:56 AM   #7
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,096
I heard draining water softener brine into the tanks will destroy them really fast. My guy replaces them all the time in ~10 year old houses from point-of-sale inspections.
Thousands gallon tanks are about $600 each delivered.
Big Johnson is offline
Old 02-07-2018, 03:09 PM   #8
Trade: Masonry
Is there a water softener on the place, here abouts, till very recently all brine rinse water would be sent down the floor/storm sewer/ field tile drain, so the salt didn't "sterilize" the septic chemistry every week or two.
You might look into using Potassium salt for the softener, More $ but healthier to drink and cook with.
Some studies have plumbed the brine discharge to distribution box(~100-200$) so the microbes aren't stunted and solids washed into the laterals.
The other thing to kill septic systems functioning is massive over use of bleaches in laundry and house cleaning.
I'd install a plastic tank if the old concrete failed from chemical/ph issues.
But fill IMMEDIATELY with water after installing and when cleaning.... they will "float"
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Golden view (02-07-2018)
Old 02-07-2018, 07:36 PM   #9
edward trowelhands
Trade: Diplomat
It never occurred to me until now, but I've never seen a water softener in this state.
Old 02-08-2018, 06:26 PM   #10
Trade: Masonry
Check out a national rain Ph map...
Then look a the ground water Phs......
At an extra cost most of the local septic tanks have an added 200-500 gallon mixing chamber ahead of the septic tank, thus reducing the Ph change and die off of "good" bacteria.
Sinking septic tank? bordercollie050 Excavation & Site Work 14 09-12-2015 11:22 AM
Tips for Cleaning Tall and Deep Tank alanhobbs General Discussion 1 03-17-2013 05:49 AM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 06:44 PM
bLowes fork lift in septic tank Michaeljp86 General Discussion 4 04-24-2008 07:13 AM
septic tank ringo7 Plumbing 1 03-31-2008 08:17 PM
