Compression Coupling Vs Glued Joint
Old 09-28-2007, 10:30 PM   #1
robertc65's Avatar
Trade: Former Electrician
It will be real handy to use compression couplings in some spots while tweaking my new sprinkler system. Do compression couplings effect the pressure or flow in any way? I don't plan to bury them, they will remain accessable in the valve boxes.
Thanks
Rob
robertc65 is offline
Old 09-28-2007, 10:38 PM   #2
Teetorbilt's Avatar
Re: Compression Coupling Vs Glued Joint
You'll never notice the difference.
Albert Einstein
Teetorbilt is offline
Old 09-29-2007, 08:49 AM   #3
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Thats right, no differe goodnce as long as you tighten the fitting good
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-29-2007, 08:03 PM   #4
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Never seen compression couplings for sprinkler piping, who makes them? What sizes? Do you mean like a pvc dresser coupling?
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 09-29-2007, 08:18 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
That is what I am guessing, I see them a lot on sprinkler systems.
KillerToiletSpider is offline
Old 09-29-2007, 10:51 PM   #6
robertc65's Avatar
They are just generic compression PVC couplers. I got them at Lowes. I saw them for 1/2" thru 4" PVC pipe. I'm using standard Sched 40 3/4 PVC for the main runs. I'm just using the couplers to connect the valves while testing and tweaking my zones.
Rob
Old 09-30-2007, 06:21 PM   #7
Rob
They are what I was thinking of, haven't seen them used for lawn sprinklers. The only sprinklers I really deal with are fire suppression. Is 3/4" big enough for your mains, I see guys around here use more 1" and 1 1/4" for mains.
Old 10-01-2007, 12:58 PM   #8
robertc65's Avatar
Yea I read a good bit about Lawn sprinkler systems before I started to install mine and many suggested using larger than 3/4" pipe. Early on I did some testing of my own just connecting a bunch of pipe together to see how many sprinkler heads I could supply on a single zone. 3/4" allows me to run 4 heads on a single zone dumping about 1/2 of water in about 45 minutes. This seems just fine with me. I'm on a well so I'm not trying to see how fast I can run it dry.
Thanks
Rob
Solution for VCT cracking @ control joint puzzledlog Flooring 2 05-16-2007 08:48 PM
Anyone know about joint ventures? djamesatl General Discussion 0 03-03-2007 06:01 PM
Removal of glued down carpet over oak floor SPEEDSQUARE Flooring 6 01-07-2007 06:54 PM
joint seal product cptkinguru Masonry 3 07-31-2006 10:44 PM
Blue v. green joint compound G.P. Drywall 27 12-05-2005 08:01 PM
