Cold Rads Downstairs Hot Upstairs
Is anyone able to help
Symtoms: Cold Rads downstairs(stone cold) - Hot upstairs Back Boiler not sure what type Gravity fed hot Water and pumped CH Pump has been replaced and is spinning No air in downstairs rads water comes out of bleed valve when opened. It has been suggested the injector tee could be problematic if the pump is running too fast???? There is water in F & E tank If timer set to CH only and demand made for CH pump spins up. Down stairs rads appear to be supplied from two different points upstairs Any thoughts greatly appreciated.... |
| Good cold weather compressor? | TempestV | Tools & Equipment | 1 | 02-04-2007 12:25 AM |
| Cutting Cold Shingles | Spencer | Roofing | 38 | 01-31-2006 09:50 AM |
| Hot and Cold Mixing | trudny | Plumbing | 1 | 01-12-2006 03:55 PM |
| calcium and lime in only cold side one bathroom only | jaimester | Plumbing | 4 | 12-30-2005 08:03 AM |
| No Cold Water | streborn | Plumbing | 2 | 03-17-2004 06:06 AM |
