#1 stunner
Code Question
How do you figure out the hot water demand for lets say 3 bed, 2 full bath house?
And where in the code book says the water heater has to deliver enough hot water for the total demand of the house hold? I am not a plumber nor plan to be I just want it for argument purposes haha. |
Trade: plumbing
Re: Code Question
Hot water- 2- showers @ 2.5 GPM=5, 2- lavatories @ 2.5 GPM=5, 1- kitchen sink @2.5 GPM= 1.25, I split the demand in half as we usually mix out water 50% hot & cold. Now this is where we do a bit of assuming, assuming each shower is 20 minutes long 20x2.5= 50 GPH, hand washing is 5 minutes 5x2.5=12.5, dish washing 15 minutes 15x1.25=18.75 GPH. Total for all is 81.25 GPH demand. We now need to locate a water heater that will heat about 81.25 GPH to 120 degrees. My incoming minimal water temperature is 60 degrees, so I need to locate a heater that will heat 81.25 gallons of water 60 degrees within 60 minutes, I use my water heater specification sheet for this and located a 50 gallon, 40k BTU heater with 50 gallons of storage will work fine. Now if I have several occupants using the system, or have fixtures with higher demands I need to increase the heater size even more as we base the size on maximum peak usage demand. There are other way to also do this, hopefully this helps.
| The Following User Says Thank You to plumber1a For This Useful Post: | Static Design (01-30-2009) |
Trade: plumbing
Re: Code Question
I forgot about the code section you asked. Chapter 5 of the California Plumbing Code for water heaters table 5-1 indicates the minimal size heaters, base upon your scenario 67 would be your minimal 1st hour rating.
#4 | |
Re: Code QuestionQuote:
average family of 3.5 is pretty busy multi-tasking? Not saying it wouldn't be "ideal" but under normal use, it seems there's a good deal of wasted capacity and unnecessary energy consumption. Just a thought, not an argument.
The Grand Wazoo
Re: Code Question
There is no code that says a house has to have hot water.
#6 | |
![]() 21st century and all that....
#1 stunner
Re: Code Question
Thanks for the replies, I wasn't sure if there was a code or not so I figured i'd ask the pros before making any assumptions.
The Grand Wazoo
Re: Code Question
You can get an occupancy permit for a dwelling without a water heater or hot water piping, provided there is a means to heat water in the dwelling.
#9 | |
for the week when the W/H crapped out during "The Blizzard." Been worried about that for 30 years.
#10 | |
The Grand Wazoo
#11 | |
#12 | |
Pompass Ass
The most you would use at 1 time would be 2 showers and maybe a kitchen sink or a DW. |
| Contractor law question for california contractors | saucedo80 | Painting & Finish Work | 7 | 04-18-2009 01:07 PM |
| gc deviates from plans code in question | kjsoto13 | Business | 20 | 01-31-2009 10:27 PM |
| City Code. Who, Where, How? | Alphabuilder422 | General Discussion | 2 | 11-07-2008 01:20 AM |
| Answer a Question with a Question | Nathan | Off Topic (Non Trade) | 151 | 10-07-2008 03:07 PM |
| 2 questions - one code, one structural | karma_carpentry | Decks & Fencing | 5 | 09-10-2006 02:55 PM |
