Clog,clog,clog.clog ,clog
Old 01-28-2008, 08:47 PM   #1
oldfrt's Avatar
It seems at least twice a week one or two of our toilets gets a good clog.
So bad sometimes ,it takes up to 30 min.to clear.They've done this since new.
On the problem side;
1)Could it be the pitch of the drain?
2)Could it be the units(American Standard 1.6gal)?
3)Flappers seem good,when I'm watching them work.
4) Maybe a little stool softener in #2 sons diet?
Solutions?
a) Something(chemical) to help dislodge the clog that is safe for septic
b)Plunger is near worn out already/so is the wife's nerves.
New wife?new plunger?
c)Bring home 5gal. buckets/everyone gets their own?
Any suggestions,serious or otherwise welcome.The wife says I spend too much time here,so a good solution will get me a kitchen pass.
Thanks,
John
oldfrt is online now
Old 01-28-2008, 08:51 PM   #2
Re: Clog,clog,clog.clog ,clog
Too easy to pass up.....
C)4) !
neolitic is offline
Old 01-28-2008, 08:59 PM   #3
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
C)4) !
isn't C4 an explosive?
I don't think that's going to help!
LOL
~Matt
BreyerConstruct is offline
Old 01-28-2008, 08:59 PM   #4
oldfrt's Avatar
Don't think I haven't considered it!
Old 01-28-2008, 09:05 PM   #5
Sure, after the C-4
you implement the bucket phase.
neolitic is offline
Old 01-28-2008, 09:12 PM   #6
cleveman's Avatar
Trade: custom home building
Is there a vent asap after the toilet goes in the floor?
Is there a tight 90 degree elbow right after the flange?
What kind of funky plumbing downstream?
Anything else troublesome?
cleveman is offline
Old 01-28-2008, 09:17 PM   #7
oldfrt's Avatar
The vents are there ,the job was done professionally.
There is a tight 90 degree after the flange .
Sinks and tub,shower drain well.
Old 01-28-2008, 09:17 PM   #8
The Grand Wazoo
KillerToiletSpider's Avatar
How old is the house?
Overhead sewer?
KillerToiletSpider is offline
Old 01-28-2008, 09:19 PM   #9
oldfrt's Avatar
Overhead sewer?
Five year old house.
Overhead sewer??
Old 01-28-2008, 09:21 PM   #10
cleveman's Avatar
does the tight 90 after the flange have a vent inlet in it? Where is the vent inlet after the flange?
cleveman is offline
Old 01-28-2008, 09:23 PM   #11
Professional Instigator
rbsremodeling's Avatar
maybe some drainoooooooooo
rbsremodeling is offline
Old 01-28-2008, 09:23 PM   #12
oldfrt's Avatar
About 18"past the flange on one and 24" on another ,the third is buried in the ceiling.
The vent is actually a y pointed away from the fixture and it is a 2" vent stack out from here.
Old 01-28-2008, 09:27 PM   #13
cleveman's Avatar
I would try to get a vent inlet in the 90, on the side or end. A long 90 is always better than a short. Maybe this isn't the cause of your trouble, but this is pretty basic-vent asap after the trap. I'm assuming that the fall is correct and that I don't have to query as to the pipe diameter.
cleveman is offline
Old 01-28-2008, 09:36 PM   #14
oldfrt's Avatar
The plumber did state that the fall was a little tight ,as we were trying to keep everything above the bottom of joists in the cellar,but I have the same problem upstairs(second floor),were the toilet has an isolated run to the cellar.
Old 01-28-2008, 10:07 PM   #15
Putty Truck's Avatar
Trade: hjrafiuoashfed
Ex-Lax.
What kind of toilet...make and model?
Putty Truck is offline
Old 01-28-2008, 10:08 PM   #16
Moderator
Double-A's Avatar
Does you use any chemicals in the tank? Blue stuff, drop in tabs?
New York Times, July 20, 2006
Double-A is offline
Old 01-28-2008, 10:09 PM   #17
cleveman's Avatar
What does it mean anyway, that it was installed professionally?
Does it mean that the plumbing will work, or the guy was well mannered?
Maybe you can get the plumber on speed dial and call him every time you have a problem. You might suggest sodomizing him with the plunger.
As far as the plunger is concerned, do you have a nice long one with a water reservoir, (the turbo charged model)? You know you have to fill this with water first. Don't plunge with air. And you can go back and forth, up and down with the plunger. If you're spending half an hour more than twice a week, there must be a Norwegian in the liquor cabinet somewhere.
cleveman is offline
Old 01-28-2008, 10:20 PM   #18
kgphoto's Avatar
Trade: Residential Remodeling
Change that tight 90 to a couple of 45's. check out the rest of the pitch. See if there is any hopping over any a/c ducts. I saw that once.
kgphoto is offline
Old 01-28-2008, 10:32 PM   #19
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
As in vent 90 or med turn 90?
Med turn 90 is ok, vent 90 not good.
Ron The Plumber is offline
Old 01-29-2008, 12:13 AM   #20
smellslike$tome's Avatar
Trade: plumbing
Sounds like the bathroom group is wet vented since fall was marginal? No mention of problems with any other fixture within the bathroom groups so we are talking about the toilets only. Your toilets are well within distance to the vent. It sounds like you are saying the wyes are installed in reverse position so that the 2" flows into the 3" downstream from and against the flow of the toilet. This is correct only if the 2" is a VENT ONLY and the 3" is in the horizontal (wet vented). 2" of the wye must be oriented above the horizontal by at least 45* and vertical is best. Check your fall with a level making sure there is fall along the entire length of this run. The 90* coming out of the flange must be either a 3" long sweep or a 4" x 3" water closet ell. NO OFFSET FLANGES! If all these things are in order scrap your AS and get a Toto with G-Max (which you should probably do anyway).
Unnecessary and will cause big problems. The first time there is a branch back up this vent inlet will be blocked negating the vent until it is cleared.
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
