Unregistered
Guest
Posts: n/a
Cistern Noise
After I Flush My Toilet (upstairs) I Get A Really Loud Noise Come Through The Pipes From Downstairs, Is This An Airlock? If So What Can I Do To Get Rid Of It? Please Help, Thanks.
#2 | |
Unregistered
Guest
Posts: n/a
Re: Cistern NoiseQuote:
#3 | |
Unregistered
Guest
Posts: n/a
Re: Cistern Noise
Replace the fill valve in the questioned toilet
Re: Cistern Noise
The noise could be water hammer and can be reduced with Water Hammer Arrestors. You can get them threaded, solder type or compression type. I bet the upstairs toilet has a quick closing type ballcock in the tank. If you have a shut off valve on the water supply of the toilet AND if it is a 3/8" outlet, get one of the compression type and install it on the valve and reinstall the supply. If you choose to replace the ballcock instead, choose a slow close type or just try slowing down the fill rate on the one you have. Hope this helps.
| odd water heater noise | 72chevy4x4 | Plumbing | 3 | 03-19-2007 08:02 PM |
| Help - how to reduce noise at heating vent | j97chung | HVAC | 3 | 01-03-2007 10:08 PM |
| Tapping noise ... | RobertWilber | Electrical | 3 | 09-07-2006 07:22 PM |
| Loud squealing noise from pipes | ChuckEA | Plumbing | 3 | 08-19-2006 05:20 PM |
| Furnace-gas forced air- high pitched noise | saturn711 | HVAC | 3 | 03-25-2006 09:52 PM |
