Cement Contact With Copper Pipe
Old 04-12-2007, 11:29 AM   #1
Capt2's Avatar
Trade: Home Improvement & Repair Contractor
I have a water main coming through a poured concrete foundation. THe copper pipe main is encased in a black plastic sleeve. When it rains water comes in through this sleeve.
Can I fill the end of the sleeve with hydraulic water stop cement? I'm hearing conflicting info on whether the cement will hurt the copper pipe inside.
Feedback appreciated. Thanks
Capt2 is offline
Old 04-12-2007, 12:29 PM   #2
POOLMANinCT's Avatar
Re: Cement Contact With Copper Pipe
why do you have to use a cementious filler??
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 04-12-2007, 03:39 PM   #3
Ishmael's Avatar
Trade: Plumbing
Why not use expanding spray-foam, or some kind of silicone sealant (like 3M 5200)?
Ishmael is offline
Old 04-12-2007, 05:40 PM   #4
Capt2's Avatar
I would be glad to use what works best.
Have you used spray foam before to hold back water?
Silicone was tried --not a complete success.
Capt2 is offline
Old 04-12-2007, 06:04 PM   #5
Teetorbilt's Avatar
5200 is a polyurethane sealant/adhesive and should stop all leakage. We primarily use it for sealing thru-hulls and other hull penetrations below the water line on boats. Got to get rid of all of the sillycone before it will work.
Look here http://www3.3m.com/catalog/us/en001/...er/output_html
Albert Einstein
Teetorbilt is offline
Old 04-12-2007, 07:22 PM   #6
DN Construction
dnconstruction's Avatar
Trade: Construction
Did you try to see if the grade was correct around the slab. Also a major factor is downspouts from gutters sometimes they are way to close to the house, if thats the case get the down spout extenders. look into checking that out first to try to prevent the problem rather than fix it like that.
Just thought I would help out.
dnconstruction is offline
Old 04-12-2007, 08:04 PM   #7
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Get some of that electrical shrink wrap, that will keep the water out.
Ron The Plumber is offline
Old 04-12-2007, 08:07 PM   #8
Teetorbilt's Avatar
Ron, I assume that you are speaking of self-vulcanizing tape. How will that bond to concrete? It bonds to itself.
Albert Einstein
Old 04-12-2007, 08:22 PM   #9
Pro Plumber
Trade: Plumber
It was a thought, and only a thought, for I don't know what it there, a picture would be helpful.
Old 04-12-2007, 10:48 PM   #10
Capt2's Avatar
I used marine grade epoxy putty. I'll see the result next time it rains.
Capt2 is offline
Old 04-12-2007, 11:22 PM   #11
Super B
skyhook's Avatar
How about a foam backer, then cover it with silicone again.
skyhook is online now
Old 04-17-2007, 09:05 PM   #12
Capt2's Avatar
OK so we had heavy rain in NJ and I had used the marine epoxy putty before it started. Basically it held temporarily then started to leak. Just out of curiosity I applied this rubbery gutter sealant that can be applied when wet and bingo, it worked no more leak.
Now if I can just get the other little foundation leaks stopped.
What is the trick to using hydraulic cement??? Can it be applied while the leak is active? I did this and the leak wiggled its way to the edge of the cement.
Capt2 is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Copper on Cement Capt2 Masonry 10 04-17-2007 10:28 PM
Copper Pipe, Pin Holes , is it happening by you?? tzzzz216 Plumbing 16 11-18-2006 08:48 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 09:39 PM
Copper pipe locator mlsgroup Plumbing 3 01-21-2006 08:42 PM
