To Caulk Or Not To Caulk? - Plumbing - Contractor Talk
Old 10-25-2015, 05:48 PM   #1
maninthesea's Avatar
Trade: High Pressure Air
Rewards Points: 30
. I had a plumber friend come to reset a toilet in the GF's rental house after a retile. He told me you should always caulk around the base of the toilet to stabilize it.
I always understood that toilet should never be caulked because if the wax ring leeks the caulk will retain the leakage and cause more problems.
He conceded that would be true in a wood floor house but here with concrete slabs it's better to caulk.
Wanted to get second third and more opinions. I asked him to leave a couple gaps in the caulking in the back where they are not visible.
maninthesea is offline
Old 10-25-2015, 05:54 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,370
Re: To Caulk Or Not To Caulk?
Caulk it, leave a gap at the back.
Inner10 is offline
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
die4irish (11-11-2015), KAP (10-25-2015), MarkJames (10-25-2015)
Old 10-25-2015, 06:26 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,401
Though we sometimes use it as a makeshift adhesive, caulk is a sealant, not a mechanical stabilizer. The proper way to stabilize a bowl if it wants to rock is with shims.
The IRC requires that a toilet be sealed at two places: the flange, usually with a wax ring, and where the bowl contacts the floor. There is no exception allowing no use of caulk or caulking only partway around.
Some folks insist that no caulk or partial caulk is better, because that lets you know sooner if the wax ring has failed. Others say that caulk is necessary to keep spills, mopwater and urine from getting in there and festering.
The IRC doesn't explain why, it just sets the requirement. And that is to caulk.
Tinstaafl is offline
The Following 6 Users Say Thank You to Tinstaafl For This Useful Post:
aptpupil (10-26-2015), CarpenterSFO (10-26-2015), maninthesea (10-26-2015), Rio (10-27-2015), SmallTownGuy (10-27-2015), Spencer (10-27-2015)
Old 10-25-2015, 06:27 PM   #4
KAP's Avatar
Trade: Custom
Rewards Points: 28,572
That was a quick thread...
Side note... Never heard of caulk being able to stabilize a 200lb woman... not what it's used for...
KAP is offline
Old 10-25-2015, 06:29 PM   #5
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 794
An age old debate.....depending who you talk to. I don't always caulk to the floor, but the times I do....yes, leave a gap in the rear.
I'm putting my 2 cents in on this because of the slab floor. I pretty much never find the flange to be stable on slabs, the ring can spin around the pipe because they aren't screwed to the slab like they are on wood floors. That's where I get out the tapcons and secure the flange ring so it doesn't spin.
I find probably 1/3 to 1/2 of existing toilets here to be caulked. But I definitely find pretty much every toilet on a slab here to be caulked, but as I said....the reason pretty much boils down to a flange that would otherwise spin so the caulking really does stabilize the toilet.
dsconstructs is online now
Old 10-25-2015, 06:30 PM   #6
Inner10's Avatar
It doesn't, it just stops piss from leaking under the bowl when you're really hammered and can't stay on target.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
KAP (10-25-2015), rdchevy67 (10-29-2015)
Old 10-25-2015, 06:49 PM   #7
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,568
I've come around on this issue and now believe you should always caulk. Piss, vomit, blood, etc all gets under there if it's not caulked. A properly set wax ring is pretty forgiving. And even though it's not meant for it, the caulk really does stabilize the toilet and probably increase the longevity of the ring.
Half of all people are below average.
Golden view is offline
Old 10-25-2015, 06:59 PM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,509
Anybody that has removed more than a few toilets and seen the stuff that gets underneath should know the answer...caulk it. If you want to leave a gap in the back, fine by me.
MarkJames is offline
Old 10-25-2015, 07:08 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,474
If I caulk it with polyseamseal, trust me, it's stabilizes and glues the the toilet to the floor
Yes, caulk it.
supersealconstruction.com
superseal is offline
Old 10-25-2015, 09:16 PM   #10
tccoggs's Avatar
Rewards Points: 874
I have seen old timers use Plaster of Paris to take up for an uneven floor instead of shims, and then caulk around it.
tccoggs is offline
Old 10-25-2015, 10:02 PM   #11
KAP's Avatar
Trade: Custom
Dude, you've been cracking me up for a couple of days now with some of your posts... whatever you're drinking while posting, keep it up...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Inner10 (10-26-2015)
Old 10-26-2015, 07:03 AM   #12
Rewards Points: 30
Thanks It was caulked with a small gap on either side in the rear. I think I'll leave them. I apreaciating knowing it's an IRC requirement.
Old 10-26-2015, 07:55 AM   #13
madmax718's Avatar
Trade: General
Rewards Points: 3,252
I always seal it up- if your wax ring fails, most likely it will just be atrickle, which will flow down the flange anyways, and not out of the side of the toilet. The caulk seal is to then prevent sewer gases from coming out, should the wax ring fail. if its unstable, the plastic shims work pretty good, then caulk it up.
madmax718 is offline
Old 10-26-2015, 11:18 PM   #14
aptpupil's Avatar
Rewards Points: 1,894
Fhb or jlc just had a thing on this. Caulk is what he said for the reasons noted. In my house I don't caulk, but after reading it, I decided to go legit and just caulk it.
I flush at least 5 times to test for leaks because I'm paranoid.
aptpupil is offline
Old 10-27-2015, 05:32 AM   #15
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,586
I just did a ceiling drywall repair in a kitchen, because their teenage son let the shower water splash out, went under toilet, messed up drywall below.
heavy_d is offline
Old 10-29-2015, 12:21 PM   #16
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,880
If the flange is properly installed this is impossible.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
SmallTownGuy (10-29-2015)
Old 11-02-2015, 08:43 AM   #17
madmax718's Avatar
Trade: General
Could you elaborate? I've seen water trickle down the side on the flange when the pipe was semi clogged, and the wax ring wasnt sealing well anymore.
Old 11-02-2015, 10:58 PM   #18
The Grand Wazoo
A properly installed closet flange sits about a " above finished floor.
Old 11-03-2015, 10:12 AM   #19
madmax718's Avatar
Trade: General
agree with you there, but how does that stop the trickle from leaking down the pipe to the floor below, or from sewer gases escaping?
Old 11-07-2015, 09:10 AM   #20
Master
Squench's Avatar
Trade: Plumbing
Rewards Points: 99
Caulk to prevent sewer gasses?
I've pulled nuts and tried to lift a well sealed w/c and almost gave myself a hernia. Had to get a razor and cut it loose. Also had unsealed that slid side-side when you bump it with your calf. Whatever your reason, code says seal so seal.
Squench is offline
Caulk Xtrememtnbiker General Discussion 47 02-19-2018 11:58 PM
How to Caulk a Crisp Corner instock Painting & Finish Work 35 02-21-2014 03:31 PM
Matching Grout Caulk to Sealed/Enhanced Grout clintonjeffries Flooring 3 04-25-2013 07:04 PM
Whats a good caulk gun for concrete epoxy? Project_Pat Tools & Equipment 18 01-02-2012 06:42 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 07:39 PM
