Cast Iron Undermount Sinks
Old 08-09-2007, 07:25 PM   #1
skidmark845's Avatar
Trade: carpenter
I'm getting mixed opinions on installing cast iron undermount sinks. Some say they are too heavy but Kohler's line is full of them. Is there any special installation required for a cast iron undermount to support the extra weight? Anyone hear of any problems w/ them due to weight?
skidmark845 is offline
Old 08-09-2007, 07:42 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Cast Iron Undermount Sinks
What is the countertop material?
I have installed hundreds of them in granite and marble tops with 0 problems, we have the countertop people epoxy mounting studs into the underside of the top.
We can't do that with Corian or Slate tops, the material is too soft for the epoxy, so we have the countertop people cut tee slots in the underside of the top and use tee bolts to hang them, being very careful not to overtighten the bolts. I use a torque wrench set at fifteen inch pounds to tighten them.
KillerToiletSpider is offline
Old 08-12-2007, 03:41 PM   #3
OleTom's Avatar
Trade: Plumber
You can check out the in wall fixture carries
OleTom is offline
Cast Iron Kitchen Sink KentWhitten Painting & Finish Work 7 06-28-2007 09:25 PM
cast iron welding ibsocal Welding & Steel Trades 2 06-23-2007 12:42 AM
PVC to Cast Iron Under Concrete dzd9fy Plumbing 14 02-11-2007 08:40 PM
Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe TDELC Plumbing 0 10-16-2006 03:31 PM
Cast Iron Pipe denick Excavation & Site Work 18 05-13-2006 09:32 PM
