Braided Steel Supply Lines
Old 01-06-2004, 12:11 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Question
I'm wondering if u can use braided steel for supply lines for hot and cold water (for a sink or shower). basically, for DIY-ers, to avoid soldering copper pipes or using pvc. seems like it be alot easier (and cheaper) to get a plumber to come in and cap a pipe with the proper threads and just run these lines urself and avoid the hassles of bending tube and turning corners. in the event of a leak, seems like it'd be alot easier to remove a hose and replace it, than have to cut and modify pipes.
also, u could do some real aggresive designing in ur bathroom/kitchen if u could use steel hoses for the water supply lines to each fixture. (this is what i'm looking to do.)
if u can do this, why isn't anyone doing it? and if u can't, please tell me why not? (i don't want to have to find out the hard way.)
thanks so much
mo
Have you ever seen braided steel lines fail? ron schenker Plumbing 6 06-09-2006 05:41 AM
Nylon Braided Supply Lines Leak dprco Plumbing 5 02-11-2006 06:25 PM
Flushmount Light with MIN 90C Supply Conductors kpikul Electrical 1 11-15-2005 06:41 PM
