Bosch Tankless Hot Water Freeze-up
Old 12-20-2008, 12:43 AM   #1
Doug161's Avatar
I have a customer who has a Bosch 250sx tankless water heater which froze and is now leaking from the heat exchanger. Has anyone ever replaced one of these before? How much of a job is it? I think this unit is around $800 new, how much to repair one? My plumber is gas certified but isn't familiar with Bosch units so I'm trying to figure out what to do.
Thanks,
Doug
Doug161 is offline
Old 12-20-2008, 12:46 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Bosch Tankless Hot Water Freeze-up
Contact Bosch, they will tell you what is needed.
Ron The Plumber is offline
Old 12-22-2008, 05:10 PM   #3
JamesNLA's Avatar
Trade: Plumbing & Electrical
So much for freeze protection!! Bosch is IMO the worst unit on the market. The poorest design - technically and mechanically. You may be able to get it warrantied but it is a challenge to replace it. I have done 4 or 5 of the noritz and 2 of the TK's and they are a pain to do. I charge 500 plus parts. It is rather time consuming and alot to take apart. IMO the heater is not worth it. Why go through all the trouble to replace the worst tankless heater on the market. That's like replacing the motor in a 1980 Datsun with a new 3000 one....not worth it.
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 12-22-2008, 05:53 PM   #4
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
It's not worth repairing. (really)
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 12-23-2008, 01:45 AM   #5
JamesNLA's Avatar
Are you being sarcastic?
----> "really"<----
-Adrock
JamesNLA is offline
Old 01-12-2009, 10:51 AM   #6
PLUMBINGITALL's Avatar
Trade: PLUMBING/ MECHANICAL LIC SC
I have had to change one on a rinnia tankless because of the contractor turning the power off. To answer your guestion it was not to hard. Put if i was not sure about it i would hire a plumber.
PLUMBINGITALL is offline
Old 01-15-2009, 12:35 AM   #7
drdog's Avatar
This should be an easy one man job. Remember there is no huge water tank, just the little radiator that heats the water. Gas, water, and electrical connections are basicly the same as the old clunker tanks. Just the way the water is heated is much more efficient, and it takes up a lot less space.
drdog is offline
Old 01-15-2009, 12:39 AM   #8
drdog's Avatar
I forgot to mention! Replacing it is easy, Repairing it may be a different story.
drdog is offline
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 10:41 PM
tankless water heaters plumberboy General Discussion 27 10-13-2008 07:14 PM
problems with Rheem tankless hot water heater configuration? KesslerDweller Plumbing 22 05-14-2008 12:35 AM
