Trade: Roofing
Boring Bit
Does anyone know of a special boring bit to basically drill out internally mounted PVC pipe fittings? Can you post a pic or forward and link?
Re: Boring Bit
This is the best I got, intended for conduit...
http://www.carlon.com/Master%20Catal...duit%20stub%22 I know for a fact that Ridgid makes a similar kit, because I've seen one in use. Darned if I can find a link to one, though. |
Trade: Roofing
Re: Boring Bit
Is it called a Pipe Reamer?
Re: Boring Bit |
Moderator
Re: Boring Bit
Several plumbing specialties companies make them.
This is one marketed by Pasco that I've used. Works well. ![]() Its called a Ram bit. Order online here. http://www.plumbingsupply.com/pvcsaver.html Put a rag down below the work area in the pipe to keep the shavings out.
Moderator
Re: Boring Bit
If you need higher quality, Wheeler Rex makes some as well that look more like the ones MD shows in his link.
| directional boring | Larry007 | Excavation & Site Work | 20 | 07-19-2011 09:05 PM |
| Decent Lock Boring Jig | brewsterb | Finish Carpentry | 9 | 05-16-2010 12:57 AM |
| More good information here than in a library! | Excalibur | Excavation & Site Work | 11 | 04-08-2010 11:05 AM |
| Used the mini skid today-Toro Dingo tracked unit | IHI | Tools & Equipment | 5 | 06-13-2006 09:22 PM |
| BORING ( Not You Nick ) | jmic | Excavation & Site Work | 5 | 06-11-2006 08:42 PM |
