Trade: HVAC
Booster Pump?
Hello,
I need to increase the water pressure to my home. We are on city water and they are only providing 29 lb's pressure. I'm trying to figure out if a booster pump would take care of my problem. Our house is a small 3 bedroom, one bath. I would install an expansion tank and a check valve at the water heater and a check valve before the pump. The two I have read about is the Flotech FP4815 and the other is a Davey pump. Has anyone installed either one of these? Recommendations? Thanks. |
Trade: Plumbing
Re: Booster Pump?
I have never installed a flotech booster pump but I know that I have replaced many of their sump pumps. They don't seem to last that long. I don't buy or install this brand for the simple fact that they are sold here at HD. They support the HO and the DO-IT-YOURSELFERS and also their product line is not of the highest quality. I recomend the DAVEY or the GRUNFOS brand.
Re: Booster Pump?
I've installed two Grundfos variable speed booster pumps. They have a VFD drive controller, and unlike the pressure switch activated variety where you get a pressure "range", the variable speed pump give you a rock-steady pressure on the gauge no matter how many taps you have open. It's a simple install, but it is around $1800 dollars.
#4 | |
The Grand Wazoo
Re: Booster Pump?Quote:
Re: Booster Pump?
The VFD pumps are more electrical than plumbing. Besides, I have more licenses than just electrical, but I am an electrician. Why? If you're hiring, I'm already too busy. All a stupid license means is that you can pass a test.
Trade: HVAC
Re: Booster Pump?
Appreciate the advice. Noise is a big concern since it will be located in the crawl space under the bathroom floor. I was at a customers house today that had a Grundfos booster and I thought it was pretty loud. I really haven't heard any of the others so I can't compare.
Trade: plumbing
Re: Booster Pump?
... that you can pass the test AND THAT YOU HAVE THE LEGAL RIGHT TO PERFORM THE WORK!!!
NJ Plumber with ATTITUDE
Trade: Plumbing Contractor
Re: Booster Pump?
PA just has county licenses right, none statewide?
Re: Booster Pump? |
#10 | |
(@40 psi). |
The Grand Wazoo
Re: Booster Pump?
Trade: HVAC
Re: Booster Pump?
I called them to see if they could increase my pessure and was told legally they only have to provide 20 lb's. Wow, appreciate the legal advice mister but could you increase the pressure. I was told due to the elevation it wasn't much they could do. I don't believe that's true because we are at one of the lower elevations in town. Don't really want to get in a pissing contest with the city so I was thinking a booster pump would be easier.
Re: Booster Pump?
Might be worth checking to see if your curb stop is open fully. I am aware of at least one new home in my area in which that was their whole volume problem. Half decent with one fixture, but flush a toilet, and it would drop to a trickle. Might not be your issue. I'm not sure if you measured that 29 pounds with a tap open or with all fixtures off. If it was with all fixtures off, then it is what it is.
Trade: HVAC
Re: Booster Pump?
Thanks for the help. I checked the pressure at an outside faucet with everything else off. My neighbor said he also has low pressure and it's always been that way. I have had this house 2 years and have just dealt with it. Now I am totally remodeling the bathroom and thought I would take care of the pressure problem while I'm at it. My guess is the pipe feeding our area is inadequate and the city doesn't want to do anything about it.
Re: Booster Pump?Ahh, that explains some of your answers I have seen on here. Just because you work for a PC doesn't make you a licensed plumber yourself, so no need for sarcasm. You could have a journeymans card which isn't much more than practical skills most places. |
The Grand Wazoo
Re: Booster Pump?
In Illinois you have to have a license just to work as a plumber, even apprentices have to be licensed by the Dept. of Health.
#17 | |
Trade: HVAC
How hard is that to get? Is there a test on code, install, or what?
The Veto toolbag, the Louis Viton of tool transport. The official toolbag of rich guys. |
#18 |
The Grand Wazoo
Re: Booster Pump?
The license test is a two part test, a written section with 250 questions on code, math, and formula, if you pass that you take the practical test, which is showing the ability to solder, use correct math to figure a rolled offset, and make an isometric drawing of the plumbing for a three story building, complete with pipe size.
| Graco Endurance Pump | Brockster | Painting & Finish Work | 2 | 09-22-2007 07:42 PM |
| 4 Sale: 1/2 HP Wayne Porta Pump | Terrence | Pressure Washing | 0 | 04-18-2007 10:43 PM |
| Well Pump Depth Question... | thepawnshop | Plumbing | 9 | 08-13-2006 09:01 PM |
| Booster pump? | Atricaudatus | Plumbing | 5 | 08-05-2006 01:05 PM |
| What Pump to Use? | dblommel | Painting & Finish Work | 0 | 03-05-2006 12:15 PM |
