Boilers In Paralel
Old 01-01-2009, 10:13 PM   #1
kenny h's Avatar
Trade: electrical contractor
Boilers In Paralel
I have a gas boiler that I paraleld a wood boiler to. the pump on the gas boiler is mounted directly on the boiler on the return. I instaled another pump on the return of the wood boiler. where I teed the wood boiler into the gas boiler is about 1 foot from the pump on the gas boiler. I kind of have a feeling that the pumps may be opposing eachother. It is a used wood boiler with no instructions but heats my whole house.
kenny h is offline
Old 01-02-2009, 12:47 AM   #2
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Boilers In Paralel
Get a plumber that knows how to pipe this kind of system to design it for you. Pay him well.
Here a hint: primary/secondary with multiple heat sources and pumping away.
If that doesn't make complete sense to you then you have no business doing this yourself and need to hire a plumber who understands it.
22rifle is offline
Old 01-02-2009, 05:44 AM   #3
Bjd's Avatar
Yea I would have to agree, unless you know how to do it.
These "Hybred" systems can be quite trickey, and if not installed correctly they can go either way, (Overheating, and or not heating at all)
However when the later happens it can have some pretty tough results.
BJD
Bjd is offline
Old 01-02-2009, 07:12 AM   #4
Plumbing is a Profession
nhmaster3015's Avatar
Funny how all these 30 year old questions are popping up all over again. Paralell piping is one way to do it but Primary-secondary piping is a much better way to go about it though.
nhmaster3015 is offline
Old 01-02-2009, 09:44 AM   #5
woodchuck2
woodchuck2's Avatar
I too would hire a plumber but i also have this for reference too.
http://www.houseneeds.com/shop/manua...2000manual.pdf
Most wood boilers are wired and plumbed the same.
woodchuck2 is offline
Burnham Boilers Bjd HVAC 20 12-07-2011 05:23 AM
boilers in tandem kenny h General Discussion 3 01-02-2009 12:48 AM
Ultra High Efficiency Modulating boilers HellisLikeNewrk HVAC 2 07-26-2008 09:10 PM
Outdoor Wood Boilers tinner666 HVAC 21 01-31-2008 03:47 PM
Replacement Boilers rej@cpintenet.c HVAC 4 01-05-2007 09:58 AM
