Trade: Plumbing
Boiler Controls...
Just out of curiosity: I've never wired a boiler; I usually leave that for the electrician. But I was just wondering if anyone can explain what is the function of the low voltage "end switch" terminals on a typical boiler control (such as Taco).
Re: Boiler Controls...
An inducer fan has a centrifugal switch on the end of the housing. When it's up to speed, the "end switch" contacts make to prove that the inducer fan is running.
That's one type of end switch, anyhow. |
Trade: Plumbing and heating
Hey Ish, the end switch in a Taco control is a set of dry contacts(no voltage ) which changes state(makes contact) when any zone calls. Normally you wire to T T on your triple aquastat.
#4 | |
Trade: Plumbing
Re: Boiler Controls...Quote:
So...long story even longer : My question is (I guess) Why is the connection between the triple aquastat and the end switch even necessary?
Ish, when you have a single zone boiler , the t-stat tells the boiler to circulate and fire if not up to temp. In a multi zone boiler you wire your t-stats to the cirulator control. Now your t-stats talk to your zone control and not to your aquastat, that's where the "end switch" comes in. It is the one talking to your aquastat letting it know there is a call for heat.
So what you did on your service call was to give the aquastat a constant call for heat, turning a cold start boiler into a warm start boiler. Hope that helps you understand, I'll be glad to help more if you need. |
#6 | |
Trade: Plumbing
That's great, Pipes. It makes a lot of sense, now. Thanks for your help. |
| Boiler Diagram | LWF | HVAC | 21 | 11-02-2010 07:26 PM |
| boiler plumbing question | 72chevy4x4 | HVAC | 2 | 05-06-2007 08:26 PM |
| Boiler furnace | Glasshousebltr | HVAC | 12 | 01-11-2007 09:35 PM |
| boiler conversion | ofourcobra | Plumbing | 1 | 12-28-2006 07:46 AM |
| hot water boiler, burners shutting off | r2d2 | HVAC | 4 | 11-23-2006 12:08 PM |
