Trade: Kitchen & Bath
Blue Block Or Teflon Liquid?
Which one do you guys prefer? My uncle (a plumber) swears by Blue Block but I've talked to others who say a good liquid w/ teflon is better.
Trade: Plumbing & Gas Contractor
Re: Blue Block Or Teflon Liquid?
There are different anti-sieze compounds for different applications.I like dope with teflon for many uses.I use strictly white teflon tape on certain appls. I use a combination of both at times, then other times I don't use either [unions].Same for gas .I use the thick gas tape at times,rector-seal yellow gas dope,a combination ,or none at all [flare fittings].Any dope I buy from my suppliers is going to be good.For Galv. steel ,water lines over 2" ,I also use wicking plus dope .No wonder there's no room in my van.
Moderator
I love me some RectorSeal. I use #5 on gas fittings and T+2 on everything else. Well, the odd time I actually do something anymore.
The T+2 will wash out of clothes, the #5 will not.
Pro Plumber
Trade: Plumber
A plumbing apparatus part will tell you on a lable not to use pipe dope or it will void it's warranty, how many of you don't know what this part is?
Sprinkler head
Maybe an RO or softener.I always read the manufactures specs. as different manufactures require different installation procedures.
Pro Plumber
Trade: Plumber
Trap Primer but there could be others.
All 3 of those I mentioned depending on manufactures,have said tape only,so i don't consider my answer wrong
.I usely use tail-piece primers so I did not know that,but I believe you. |
Trade: Plumbing & Heating
Blue Block over teflon...Never leaks. Blue Block on those tough to get old unions.
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Glass Block Transition | Paul_NJ | Ceramic & Stone Tile | 0 | 03-15-2007 08:14 AM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
