Black Iron Gas Lines
Old 01-01-2011, 09:27 PM   #1
bluebird5's Avatar
Trade: Licensed G. C. carpenter, flooring, remodeling
Rewards Points: 694
Wink
this is a personal project and i know someone is going to say why aren't you in the diy forum but here it goes and the answer is i like hearing from the pros
how tight do you tighten black gas fittings to the pipe (tight as you can? hand tight and then 2 turns? hand tight and 1 turn?)
when working with rectorseal if you tighten a fitting and need to back it off a little to straighten it up is it like teflon one way only or is it ok to tighten and then untighten a little does the pipe thread sealant loose any seal or is it best to take the fitting off recoat the threads and put it back?
bluebird5 is offline
Old 01-01-2011, 09:34 PM   #2
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Re: Black Iron Gas Lines
i tighten to feel....good luck
rex is offline
Old 01-01-2011, 09:46 PM   #3
SC sawdaddy's Avatar
Rewards Points: 1,018
Tighten it to somewhere between doesn't leak and about to strip it out.
No, you cant hold my hammer. Where is yours?
SC sawdaddy is offline
Old 01-01-2011, 10:05 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 1,222
Too tight & you can crack fittings. You are going to pressure test aren't you?
griz is online now
Old 01-01-2011, 11:10 PM   #5
bluebird5's Avatar
Rewards Points: 694
yea i was thinkin somewhere around 10psi since gas is 2psi what u think?
Old 01-01-2011, 11:12 PM   #6
bluebird5's Avatar
Rewards Points: 694
haha i like that sawdaddy very specific
Old 01-02-2011, 09:30 AM   #7
OleTom's Avatar
Trade: Plumber
I hate to sound like commercial BUT the sealant is so important to me "In my opinion" Loctite is the best
Google them you will find them easily I use LOCTITE THREAD SEALANT 545 on most everything it's expensive but well worth it
But don't buy a case and keep it in the gang box or it will disappear LOL
OleTom is offline
Old 01-02-2011, 09:42 AM   #8
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Sorry to ask - but...
Do you have a Gas Ticket? Here in North Vancouver as homeowner I can wrong my own plumbing lines, low voltage wiring, framing, drywall, painting, electrical, and on and on... but Gas is a No Go.
I would make sure your allowed to do this work first.
And as my fitters like to say "No Bubbles. No Troubles."
JohnFRWhipple is offline
Old 01-02-2011, 10:04 AM   #9
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,476
Most residential systems are about 7" which equates to 1/4 psi. We pressurize to 25lbs.
It's your place and don't intend to judge. But, it would behoove you to pull a permit for the project. If for whatever reason, an incident were to arise, even if it were unrelated, your homeowners insurance will have a leg to decline responsibility.
flashheatingand is offline
Old 01-02-2011, 10:08 AM   #10
Trade: H.v.a.c.
If you use pipe dope and tape, you will be able to get away with going back. Tighten like a handshake, firm, but not over the top.
Old 01-02-2011, 12:49 PM   #11
Rob PA's Avatar
its around my area...gas co will tell you dope and tape.......plumbing vendor says dope no tape?? but i know who will red ticket me if i dont do it there way
we do dope/tape gas co calls for 3lb test...we do at least 10 pound
i tighthen snug tight but dont go nuts
Rob PA is offline
Old 01-02-2011, 04:23 PM   #12
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 228
A little off-topic, but doesnt anyone use lampwick anymore with dope?
Splinter is offline
Old 01-02-2011, 07:51 PM   #13
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
People do still use it on heating systems in the UK. I think it's a kind of hemp wick they use with the plumbers dope. You cant use it on drinking water pipes anymore though because of bacteria growth.
www.bcconstructionllc.com
BCConstruction is offline
Old 01-02-2011, 09:03 PM   #14
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Tapered pipe threads on pipe and fittings need no sealant to be leak free if the pipe is threaded perfectly and the fitting threads are also perfect.
KillerToiletSpider is offline
Old 01-04-2011, 07:17 AM   #15
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
I can't say I've ever heard this before. NPTF Dryseal are the only ones I know of that donít actually require sealant, but even then, itís still often used for added leak prevention and to prevent galling. As far I know, regular NPT threads always require a sealant. Here, our plumbing and gas code require it. Most will even use both tape and dope on threads for LP and natural gas piping.
DuMass is offline
Old 01-04-2011, 05:19 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,128
I think he means in theory.
Inner10 is online now
Old 01-04-2011, 06:11 PM   #17
Trade: Construction
Inner this is of subject but is it ok to run low voltage lines like Ethernet and phone next to mains power or is it best to run them apart? I'm being told 2 different things by 2 different sparks and I thought you would be the guy who knew.
Old 01-04-2011, 08:24 PM   #18
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,885
I'm not Inner, but I'll answer anyway. Asked in the right place, you'd have had your answer much sooner.
The answer is no. Not only against code, but with the lines up against each other like that, there can be inductive coupling that will induce 60 cycle hum into the the signaling lines. Not good.
Tinstaafl is online now
BCConstruction (01-04-2011)
Old 01-04-2011, 08:47 PM   #19
Trade: Construction
Thanks Tin. Thought as much but wanted to be sure. One guy is using the easy way out trying to run them in the existing runs. Gonna get either run to run new runs for the low voltage stuff now.
Old 01-04-2011, 10:11 PM   #20
Inner10's Avatar
There is no code restriction in my area regarding that. In many circumstances it cannot be avoided. Tin is correct in that inductance problems occur if they are ran together especially for long distances. Avoid running network lines near transformers, fluorescent light fixtures and power wires in general.
If you have to run them together in a tight spot, fan them out after.
Black & Decker Recalls Random Orbit Sanders Snobnd General Discussion 1 09-11-2010 06:55 AM
ABS to cast iron? pzeiler Plumbing 9 06-09-2010 09:57 AM
nailing into gas or freon lines Javelin350 Windows, Siding and Doors 15 10-10-2009 09:16 PM
iron filter for well water...Hello, What would be the best filter/system for iron an justdoitright Plumbing 3 09-10-2009 07:43 PM
Angle Iron to Block Tommy C Masonry 37 04-12-2009 09:42 AM
