Black Drain Pipe??
Old 01-06-2007, 09:38 PM   #1
pauls painting's Avatar
Trade: paint& drywall
Black Drain Pipe??
rehabing a house for my brother plumbing nightmare>>>. broke slab in bathroom as its an add-on at some point in time. need to know how remove an elbow on black pipe drain from sink and how to plug line.as i am installing a new sink and vanity. also how do i cut this type of pipe.
pauls painting is offline
Old 01-06-2007, 09:39 PM   #2
mdshunk's Avatar
Re: Black Drain Pipe??
ABS plastic? Or cast iron? Both are black. For ABS, a hand saw or a hack saw or a sawzall. For cast iron, a cast iron "snapper" tool or a grit blade in a sawzall. To plug the line temporarily, use an expansion plug or test plug. Two different names for the same basic thing.
Don't take this the wrong way, but I'm really puzzled why a painter is doing plumbing? Tsk, tsk.
mdshunk is offline
Old 01-06-2007, 10:32 PM   #3
kennewickman's Avatar
Trade: General/Plumbing Contractor
Dont take this the wrong way, but I'm really puzzled why an electrician is answering this question- lol
kennewickman is offline
Old 01-06-2007, 10:59 PM   #4
mdshunk's Avatar
Because nobody else did. Simple as that.
Do you have some special issue with the technical accuracy of my answer, or are you on the sauce tonight and felt like you needed to make some comment like that to stir the pot? Stick around, and you'll find that I'm much more than an electrician. I'm also a fat-headed know it all.
mdshunk is offline
Old 01-07-2007, 01:30 AM   #5
Actually I was just kidding, I have seen quite a few of your answers on other posts & noticed you seem well educated in the plumbing field (for an electrician)
Old 01-08-2007, 11:29 AM   #6
TimNJ's Avatar
Is this pipe running under the slab? I hope it isn't old orangeburg, if so, get rid of it or reroute your new piping and abandon it.
TimNJ is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
drain pipe holes up or down? jimb317 Plumbing 9 06-06-2007 04:22 PM
Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe TDELC Plumbing 0 10-16-2006 03:31 PM
How to rock around drain pipe that stick out 1/4in from stud? ruskent Drywall 11 04-27-2006 12:02 AM
Old black water pipe pedro mac Plumbing 4 12-28-2005 04:13 PM
