Best Way To Bust Up Concrete Floor
Old 02-11-2010, 11:19 PM   #1
Redman's Avatar
Trade: Remodeling/Painting
Send a message via MSN to Redman
I have a couple jobs that I need to bust up the concrete floor in order to move the drains. Just wondering what your process is and what kind of power tools work best.
Thanks
One day at a Time.
Redman is offline
Old 02-11-2010, 11:33 PM   #2
SEMI RETIRED
griz's Avatar
Re: Best Way To Bust Up Concrete Floor
Saw cut, then demo out usually with the Bosch Brute.
griz is offline
Old 02-12-2010, 12:39 AM   #3
Griffino's Avatar
Trade: General Contracting
Agree ^^^
Rent a large saw, rent a large jack hammer and a few neighbor boys for the labor; this job is brainless and time consuming. If you're cutting heat tubing (as I did on my last job like this) also rent a smaller hammer to chip around the tubes to couple them after.
Griffino is offline
Old 02-12-2010, 05:28 AM   #4
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Send a message via Skype™ to jlhaslip
cut and a Hitachi Demolition Hammer (electric) because that is what I have...
jlhaslip is offline
Old 02-12-2010, 06:52 AM   #5
Project_Pat's Avatar
Trade: Drywall jockie
If you are doing this indoors try to open a window and have someone with a garden hose helping you............The dust and fumes from a concrete saw indoors can be brutal.
Project_Pat is offline
Old 02-12-2010, 11:00 AM   #6
rustyjames's Avatar
I would avoid dry cutting inside, the dust generated is going to be a major mess. Either wet cut or no cut--just bust it up (with a sledge or electric hammer) and patch.
rustyjames is offline
Old 02-12-2010, 06:19 PM   #7
plummen's Avatar
Trade: plumbing/electrical/hvac
the best way ive found to remove concrete is an apprentice with a strong back and weak mind!
plummen is offline
Old 02-12-2010, 06:26 PM   #8
Mellison's Avatar
Trade: Home Improvement General Contractor
Cutting makes too much dust.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Old 02-12-2010, 08:02 PM   #9
Gumby
IanS's Avatar
Trade: Concrete
Yes what they said. If dust is a problem just take the walls down see....
There is more profit in the end.
IanS is offline
Old 02-12-2010, 08:42 PM   #10
The Grand Wazoo
KillerToiletSpider's Avatar
20 LB sledge and a big laborer.
KillerToiletSpider is online now
Old 02-12-2010, 09:34 PM   #11
Sewer Rat's Avatar
Trade: Plumbing
I will wet cut the floor to keep the dust down. Have a shop vac suck up the water as you are cutting.
Sewer Rat is offline
The Following User Says Thank You to Sewer Rat For This Useful Post:
protechplumbing (02-15-2010)
Old 02-12-2010, 09:42 PM   #12
Warren's Avatar
Trade: framing/remodeling
If you only need a small area demo'd, use an sds drill and drill holes about 6 inches apart around the perimiter. Then use the jackhammer to bust out inside the holes. We have done this many times for installing footer pads on remodels. I agree with the saw/dust. It can get unbearable!
Warren is offline
Old 02-12-2010, 10:15 PM   #13
BCConstruction's Avatar
Trade: Construction
Few of these spaced correctly should do the job.
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 02-14-2010, 06:53 PM   #14
MB1's Avatar
1- Bosch Brute
1- 5 gallon bucket 1/2 full of water
1- Mop from the dollar store
Place wet mop over the bit while in use - 99% dust-free
MB1 is offline
The Following User Says Thank You to MB1 For This Useful Post:
BuildersII (02-16-2010)
Old 02-14-2010, 07:27 PM   #15
Handle It!
MALCO.New.York's Avatar
Originally Posted by MB1 View Post
1- Bosch Brute
^^^^ WHAT HE SAID! ^^^^
http://www.builderbill-diy-help.com/...s/ba-bosch.jpg
The only missing ingredient: Someone else to cart it away!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 02-14-2010, 07:40 PM   #16
JumboJack for president!
XanadooLTD's Avatar
Trade: Hilti walking billboard
Concrete saw and then i use the Hilti TE 1500 with the drs dust collar with vacuum. Cleans up dust pretty well.
XanadooLTD is offline
Old 02-15-2010, 11:50 AM   #17
bathroom guru
jarvis design's Avatar
I learned a nifty trick from my old plumber buddy. If he was excavating a trench for a drain he would start with his jackhammer and make a hole about a foot square, then remove the sand/dirt under where he is going and use a sledge to bust out the concrete. Once you have the dirt gone from where you want to go, the concrete busts up pretty easy.
Bathrooms Built for Life.
www.JarvisDesignBuild.com
519-495-4062
jarvis design is offline
The Following 2 Users Say Thank You to jarvis design For This Useful Post:
protechplumbing (02-15-2010), seeyou (02-15-2010)
Old 02-15-2010, 07:39 PM   #18
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Sawcut with water. Then cross cut into squares. Then drive a tap-con in the first block. Use a claw hammer on the tap-con to pull the first square of slab up.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 02-16-2010, 03:11 AM   #19
ContrBob's Avatar
Trade: general contractor
Just rent a small electric jackhammer with a moil point bit. Probably around $20 for 1/2 day
ContrBob is offline
Old 02-16-2010, 03:48 AM   #20
BuildersII's Avatar
Trade: General
Here's an interesting product: http://www.archerusa.com/
It apparently expands and causes a pressure of around 20000 psi that will cause concrete to buckle. I don't know how well it would work for you, but drilling the holes you'd need with a hammer drill will produce vastly less dust and noise than a saw or jackhammer.
BuildersII is online now
Concrete Basement Floor sealer..? Ryan03 Concrete & Paving 8 06-28-2010 12:23 PM
Brick "cistern" under concrete floor jarvis design Remodeling 19 05-29-2009 11:39 PM
Interior Concrete Floor Discussion genecarp Concrete & Paving 5 01-23-2009 06:59 AM
Hmmmm...what to do with concrete floor carlspackler Painting & Finish Work 5 11-11-2006 08:03 PM
Concrete floor in a pole barn thinkncabin Masonry 3 03-31-2006 06:45 PM
