Trade: Renovations
Before Or After The Tank
The issue here is that I have to cut into the line for a supply to an out building, and there is no room in the existing pex to add on the house side of the 'tee' under the bladder tank. (The connectors are too close to each other). Can I cut in on the pump side of the tee? (Between the filter and the tank). It doesn't seem to me to make any difference, but that is why I am asking.
The Grand Wazoo
Re: Before Or After The Tank
You can, but you won't have any water pressure on that branch.
Plumber
Trade: Plumbing
First you need to determine where is the back-check valve. Is it at the well head or at the pressure tank location. As long as the back check is before you tee off you'll be fine.
If it's after (or near the pressure tank) you will only have flow when the pump is refilling the tank. |
#4 | |
Plumber / Carpenter
Re: Before Or After The TankQuote:
Quite correct, as long as you install the T AFTER the check valve you will be fine and you will have pressure. If you do not see a check valve and you have a submersible pump the check valve is usually at the head of the pump UNLESS it has failed and one was placed further up on the line. The check valve is usually a small brass section slightly larger than the pipe and about 3 to 4 inches long. I have seen what they call "Tank Tees" which has a built in check valve.If you install the T before the check valve you will only have "Pump" pressure and every time you turn on a faucet the pump will run making for an early point failure. Last edited by Bill; 03-12-2008 at 08:52 PM. |
Trade: Renovations
Thanks, guys, I'll look for the check valve. Everything I drew is existing already (although not as pretty), the 'tee' is simply that, there is no difference in the pressure from one side to the other, the tank is 'tee'd' off the supply line from the pump through the filter.
If I hear nothing further from you I'll go ahead and cut in! (Gotta love pex)
#6 | |
Trade: Framing
Trade: Renovations
Tks for all your replies. It's over now. No check valve was present (unless it was integral to the pump which I doubt). Cut in, supplied the new system, pressure came up and the pump cut off. Ran the water in the new system and no cycling of the pump, so all is well. Only had a couple people near me to make sure I wasn't blowing it so I appreciate all your input, Rich.
| Heating Oil Tank Venting | RenaissanceR | HVAC | 1 | 01-02-2008 07:41 PM |
| septic tank replacement | loogout1 | Excavation & Site Work | 14 | 10-05-2007 08:23 AM |
| Propane tank relocation... | ruskent | HVAC | 4 | 03-19-2007 01:05 AM |
| Oil Tank | KGB | HVAC | 1 | 03-18-2007 08:54 PM |
| oil tank location question | Vermonster | HVAC | 3 | 10-19-2005 09:14 AM |
