Basement Toilet Flange
Old 02-18-2010, 08:10 PM   #1
jtequipment's Avatar
Trade: Home Restoration Services
Im no plumber. I typically delve in cosmetic upgrades and restoration but I got a small flooring job from a gal, in a basement bathroom. the problem is when the toilet came up it brought with it some of the cast toilet flange. The part that is destroyed is the closet bolt section that mounts the toilet. Im trying to figure out how to either repair this flange using a patch kit or how to replace the flange completely. this is a cast flange mounted to a cast drain pipe. any help guys? thank you!
jtequipment is offline
Old 02-18-2010, 08:23 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Basement Toilet Flange
Pretty easy fix, break out the old one and yarn and pour a new one to replace it.
KillerToiletSpider is offline
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
breid1903 (02-20-2010)
Old 02-18-2010, 08:24 PM   #3
Its all ball bearings
angus242's Avatar
Trade: Tile
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Old 02-18-2010, 08:25 PM   #4
The Grand Wazoo
Originally Posted by angus242 View Post
In Illinois that is a code violation.
Old 02-18-2010, 08:29 PM   #5
angus242's Avatar
Trade: Tile
I suppose my disclaimer was the question marks. I'll humbly back out of the plumbing forum now
Angus
Old 02-18-2010, 08:43 PM   #6
angus242's Avatar
Trade: Tile
I'm not questioning you about this but haven't I seen these things in the big box stores around here? If so, how can they sell them if they aren't code compliant? (I supposed that's a figurative question)
Angus
Old 02-18-2010, 09:28 PM   #7
instead of replacing the whole unit due to a small broken section, I was considering getting a repair patch, drilling the existing flange and riveting the repar section too it. also if the iron were too soft and brittle to hold rivets how about drilling, tapping and bolting the repair section directly to it? any thoughts?
Old 02-18-2010, 10:22 PM   #8
plummen's Avatar
Trade: plumbing/electrical/hvac
got a picture of the problem?
plummen is offline
Old 02-19-2010, 07:51 AM   #9
mrmike's Avatar
Trade: Electrical & Carpentry
I've used one of these before with success. The wood aroound the flange has to be solid. If it is concrete you would have to use concrete fastener screws screws to fasten it down. Hope this helps...........
mrmike is offline
Old 02-19-2010, 07:59 AM   #10
Thats what I got. Ive used them on above grade bathrooms, where they slide under the ex. flange and screw to the plywood. On the concrete I was thinking it would just have to be tapconed into the 'crete.
Old 02-19-2010, 12:32 PM   #11
The Grand Wazoo
For the same reason that the ones in Cook Co sell romex even though you can't install it in the county.
Old 02-19-2010, 03:18 PM   #12
angus242's Avatar
Trade: Tile
Kind of. But there's a difference in selling something that's not compliant in Cook but can be used in surrounding counties and selling something that's a violation in all of Illinois. No?
Just doesn't m'e aense they'd be allowed to sell them. Just like certain fireworks.
Angus
Old 02-19-2010, 05:00 PM   #13
The Grand Wazoo
There is no law against selling something that is not code approved, it is up to the installer to know. They sell all sorts of stuff that is not code compliant.
Old 02-19-2010, 06:01 PM   #14
angus242's Avatar
Trade: Tile
Well that sucks.
Angus
Old 02-20-2010, 09:54 PM   #15
breid1903's Avatar
Trade: master plumber, master electrician, drain cleaner
brass knuckles? breid.............
breid1903 is offline
Toilet flange 1/2" proud of floor cleveman Plumbing 30 11-06-2009 09:55 PM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 01:50 AM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
New help with this toilet flange Mike Finley Plumbing 2 06-16-2006 09:27 AM
