Plumber / Carpenter
Backflow
Hi, been a member here for quite some time, even though I do not post much. I felt the need to post this so as to help other plumbers save time, money and nerves in the future.
I did the plumbing (Waste and supply) at a Moe's restaurant in Blacksburg, VA. This job consisted of about 600 linear feet of water lines as follows Cold, this is for hand wash sinks, toilets, urinals........ Filtered cold, for ice machine, soda machines........... 110 degree tempered, for hand wash sinks, bathroom sinks.... 180 degree hot, for dish washing........... 180 degree hot water recirculated lines, for recirculating hot water through system So as any plumber can see, with all these different lines going to different places it can get confusing. I personally oversaw the job, I was there every day. When all plumbing inspections where complete and all systems tested, I got paid and went home. I got called back because there was 180 degree water going through the urinal. I went back (3 hour drive) and yes, there was hot water in the urinal. I spent almost 3 hours tracing lines and found out that they mounted a 2 way hose adaptor on the mop sink faucet and they leave the hot and cold on all the time (They have a garden hose with a sprayer head), so when the cold water in the bathrooms ran, it sucked the 180 degree water through the mop sink faucet and sent it through the cold water pipes. A simple swing check valve fixed the problem. So as a note to all plumbers, if you hook up any mop sink faucet, or any faucet like a pre-wash sprayer where the faucet handles can be left on and be used by compressing a lever, then add a spring (Vertical) or a swing (Horizontal) check valve. It will save a lot of BS down the road. Maybe some have already run into this, others who do not know will say they already do and I am an idiot for not knowing. I do not care, I am just trying to share with others what I have learned the hard way. Hope this will be usefull to all |
The Grand Wazoo
Re: Backflow
One of the commercial manufacturers, I believe it is T&S Brass but not positive, makes a mop sink faucet with integral checks, perhaps start installing those on commercial jobs.
Plumber / Carpenter
Re: Backflow
yes they do, but I did not supply any fixtures or valves on this job, that fell on the GC and they had specs from Moe's. You know how that goes
The Grand Wazoo
Re: Backflow
I'd bill the GC for the time then.
Plumber / Carpenter
Re: Backflow
You know it, 3 hours there, 4 hours for 2 men, and 3 hours back. Already told Gc, he said fine because he found out that the architecs know that this problem existed in all the other restaurants they done, but they did not mention it in the plans. So they are going to back charge the architecs for it. maybe this will make them add a notation on the P pages then!!
OOPS, I almost forgot, architecs are NEVER wrong |
Moderator
Re: Backflow
Great heads-up for any plumbers installing utility hot and cold outlets in commercial and residential.
Thanks for posting it.
FT.WORTH,TX MASTER PLUMB
Trade: plumbing
Re: Backflow
Good post
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: Backflow
Learned this one a long time ago, that's why I akso add a vacuum breaker on the lines above the faucet.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Plumber / Carpenter
Re: Backflow
I do too, especially with hose bibs. We had to install 2 on one job, one inside and one out. The walls were cinder block so the inside one was a boiler drain so we could mount as tight to the wall as we could, screwed on a vacume breaker, tightened down the lock nut, then cut the lock nut off so no one could remove the breaker.
#10 | |
The Grand Wazoo
Re: BackflowQuote:
| Exhaust fan for attic | Handyman | Construction | 22 | 10-22-2007 11:18 PM |
| Backflow testing | pyroracing85 | Plumbing | 24 | 09-10-2007 01:49 PM |
| Backflow and Check Valves | rjordan392 | Plumbing | 7 | 08-20-2006 08:50 PM |
