Attic Plumbing
Old 06-26-2017, 02:45 PM   #1
rpmhillc's Avatar
Trade: Home Improvement
Attic Plumbing
I am looking to add a rain head in my shower. My bathroom has attic space above it. I live in maryland. Is it safe to bury a water line in the attic with the blown insulation above and wrapped in black foam pipe insulation? It's only going about 3 feet of total length and would be touching the attic side of the drywall. Quite a bit of insulation above it as well as the heat from the inside of the house keeping the drywall warm. How safe would you say?
rpmhillc is offline
Old 06-26-2017, 03:58 PM   #2
rrk's Avatar
Rewards Points: 1,884
Re: Attic Plumbing
The only way I would do it in a shower only is also install a toe touch spout diverter also. that would drain the water from the shower head line.
There may be an official name for it but I don't remember.
I have used a couple in the past, my plumbers idea and so far has worked fine. Spout was 12" or so above the floor, diverter was part of the shower valve and once water was off it opened by itself.
rrk is online now
mrfixitplumbing (07-17-2017)
Old 06-26-2017, 04:49 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,931
Re: Attic Plumbing
Running it just beyond the drywall and with plenty of insulation above, I'd have no problem doing it.
MarkJames is online now
Old 06-27-2017, 08:25 AM   #4
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 168
Re: Attic Plumbing
I would think the biggest trouble spot would be where the vertical pipe penetrates the attic into the elbow. I might climb up there and spray a bunch of insulating foam around it just to be safe and probably insulate the pipe in the wall down a foot or so as well. That part of the pipe will hold water and be more likely to freeze than the horizontal run, imo. Most of the water in the piece going across will likely drain out of the shower head when the tap gets shut off, I think. The spray foam acts as an insulator and a vapor barrier. The vapor barrier has always been more of the issue for me than the insulation. Of course, I live in a 40 below climate too.
Ernie in Dawson is offline
Old 09-19-2017, 06:04 AM   #5
Jerry L. Garcia's Avatar
Trade: Denver Bath & Kitchen Remodel Group
Rewards Points: 30
Re: Attic Plumbing
All you need to do is to run it beyond the drywall and also to put plenty of insulation above it. I don't feel that I would ever have any problem doing it.
Jerry L. Garcia is offline
Vapor Barrier for Finishing Old Attic nycphotography Insulation 19 08-28-2012 09:25 PM
Toys in the Attic Snobnd Off Topic (Non Trade) 3 07-10-2012 09:22 PM
New house no vent. New plumbing code? pxjiang Plumbing 13 02-14-2012 10:13 PM
Copper Industry Launches New DIY Architectural and Plumbing Videos Grumpy Roofing 0 06-03-2011 09:32 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 07:57 PM
