Attaching A New Line To A Cleanout
Hello:
I'm installing a small bar with a sink in a basement rec room. The bar will be against a wall, open on the left, and up against a utility closet on the right. The ceiling is finished. There's a small access panel directly above where I need to install the cabinets. The access panel is for access to a drain cleanout. I want to do two things with this cleanout. First, I want to close off the access panel, so I was thinking of connecting a drain line to the cleanout and running it about 8' to the right to the utility closet. The cleanout would now be in the utility closet. I also plan to have the bar sink next to the utility closet. I'll place a sanivite pump in the utility closet, the bar wink will drain into the sanivite. Can I pump the waste from the sanivite up to the new line I just attached to the cleanout? I'll add a new cleanout where the sanivite and new line connect. I would save me a lot of time and make things a lot easier. Thanks. |
#2 | |
Pompass Ass
Re: Attaching A New Line To A CleanoutQuote:
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| clogged kitchen waste line | beapainter | Plumbing | 2 | 01-09-2010 02:55 AM |
| Line levels | Tscarborough | Masonry | 26 | 03-15-2008 12:58 PM |
| So I was popping a straight line today.... | wallmaxx | Framing | 10 | 01-22-2008 09:23 AM |
| Replacing residential sewer line | threequez | Plumbing | 1 | 10-17-2006 05:09 AM |
