Alternative Way For Vent Stack?
Old 07-18-2017, 09:26 PM   #1
Victoria Chan's Avatar
Trade: General contractor
Rewards Points: 8
We just finished a remodeling bathroom job, but found there is no existing vent stack. AAV is not allowed in MA.
House will sell soon, will this affect the home inspection?
Victoria Chan is offline
Old 07-18-2017, 09:35 PM   #2
rrk's Avatar
Rewards Points: 1,884
Re: Alternative Way For Vent Stack?
How did it pass plumbing inspection from the recent remodel ?
rrk is online now
Old 07-18-2017, 09:58 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 180
I sure hope so.
And for what it's worth, an AAV is not a substitute for a vent stack. It is, at best, a substitute for an individual fixture vent. And not the best one at that. And not allowed in many, many areas.
Delta
I have an Edifice Complex.
Rio (08-28-2017)
Old 07-18-2017, 10:02 PM   #4
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,112
Well Victoria, you might be held accountable for the missing vent stack. It is not fair I know, but it may go that way.
Ask the home owner if they are willing to pay for putting one in. I would think that any half-way decent home inspector would catch that.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
greg24k (07-19-2017)
Old 07-19-2017, 02:45 PM   #5
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,386
Andy.
I think she's the seller. The last plumber I hired did an AAV for the whole basement bathroom. Apparently it's allowed here. He won't be rehired. The sloppiest and laziest SOB I've ever met.
Big Johnson is online now
Old 08-07-2017, 11:07 AM   #6
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 168
I would think there has to be a main vent stack somewhere in that home's attic. I would definitely try to find a continuous wall to run a vent up for the bathroom and tee into it or if worse came to worse, cut in a neoprene flashing in the roof and run a vent. That's another roof penetration that would be nice to avoid, though.
As for the AAV's, our inspectors frown on them but usually allow us some leeway for kitchen island vents or adding in a laundry in old houses. I don't recommend them for venting toilets or whole baths for sure although some guys do it from time to time and they work.
Ernie in Dawson is offline
Old 08-09-2017, 12:14 PM   #7
blueskyglass's Avatar
Trade: replacement windows
Rewards Points: 88
Usually the vent stack has to routed above the roof to be compliant. Venting into the attic not code compliant. If you can't see it on the roof then you have a problem.
Rod
blueskyglass is offline
Old 08-28-2017, 06:04 PM   #8
Rewards Points: 8
Well, late update, sorry.
We are trying to determine whether this is caused by the vent. There is definitely vent close to the bathroom. We don't want to take risk if we install a new vent, the problem is still existing. So we tried drain cleaner two nights, the sound has reduced a lot. But it will come back really really soon(about 3-4 days). The water supply and drain for the bath sink have two 90 degree elbow.
Pressure testing vent stack? MNBobcat Plumbing 2 02-02-2014 10:54 AM
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 09:10 AM
main stack venting PARENOS Plumbing 7 10-08-2012 07:31 PM
Puzzle me this: Mike(VA) Off Topic (Non Trade) 26 07-16-2009 06:54 PM
