Air Chambers Necessary?
Old 07-24-2007, 10:08 PM   #1
kermmonk's Avatar
Trade: builder
Hey Guys,
I am self contracting a new house for myself. 2 baths. Radiant heat with radiant boiler also providing hot water for house.
Are air chambers necessary at every fixture, just at the dishwasher and washing machine or not at all. I spoke with the plumbing sub yesterday, he says in our part of the country they are not necessary. (Northeast TN)
What do you think?
Thanks,
Kermmonk
kermmonk is offline
Old 07-24-2007, 10:10 PM   #2
kermmonk's Avatar
Trade: builder
Re: Air Chambers Necessary?
Also,
Should I specify 3/4 inch copper main lines with 1/2 branch lines. We have no building codes here whatsoever.
Thanks,
Kermit
kermmonk is offline
Old 07-24-2007, 11:19 PM   #3
The Grand Wazoo
KillerToiletSpider's Avatar
We put air chambers on every opening, and I highly recommend it.
KillerToiletSpider is online now
Old 07-25-2007, 10:52 PM   #4
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
I put airchambers on every fixture, as for mains 1" cold 3/4" hot minimum on all residential we do.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 07-26-2007, 07:26 PM   #5
just a dumb plumber
crb555's Avatar
Trade: Plumbing / HVAC
I will chime in as well in favor of air chambers. Either a mechanical type, or a tee with a 12" piece of pipe with a cap at a minimum. On a house, I would imagine a single type B WHA would suffice if you used the tee and cap method.
!" min main on cold water, 3/4 on hot water.
CRB
crb555 is offline
Old 07-26-2007, 08:52 PM   #6
kermmonk's Avatar
Trade: builder
Thanks guys!
Good info. The plumbers here say they do not use air chambers on any opening. Is there something I am missing. They say they never have call backs for hammering. Do the air chambers serve any other purpose?
One plumber told me they are only necessary in Florida!
Kermmonk
kermmonk is offline
Old 07-26-2007, 09:04 PM   #7
just a dumb plumber
crb555's Avatar
I would feel compelled to ask that plumber just how the laws of physics differs in Florida.
It will hammer without some type of arrangement to either bleed the air completely from the line, or to absorb the shock of pressure meeting air.
Crb
crb555 is offline
Old 07-26-2007, 09:25 PM   #8
kermmonk's Avatar
Trade: builder
I had the same thoughts about the Florida remark.
Kermmonk
kermmonk is offline
Old 07-29-2007, 05:38 PM   #9
Keep me bussy
Work is good's Avatar
Trade: Home Remodeling
Maybe water can flows without air over there
If it`s not specifiesd different by the local low
Work is good is offline
Old 07-30-2007, 06:29 PM   #10
A plumber that doesn't put in airchambers most likely doesn't wipe his solder joints and is just there to get the job done and doesn't care how well or if it works.
Old 07-30-2007, 07:42 PM   #11
The Grand Wazoo
Originally Posted by kermmonk View Post
Thanks guys!
Kermmonk
We install them in Chicago by code.
Old 07-30-2007, 08:55 PM   #12
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
We don't put in air chambers, not just me, but every plumber you ask here will tell you no air chambers, only if there needed, and there not needed. If you need air chambers, your water pressure is too dam high.
I wipe my solder joints.
Ron The Plumber is offline
Old 07-31-2007, 06:43 PM   #13
Water hammer isn't just caused by pressure it's also from velocity. I have seen entire housing projects that have PRV's on the mains and the plumbing contractors had to go back and add mechanical arrestors on the washing machine lines and all the lavs and kitchen water lines.
I would rather just do it right the first time and avoid any issues.
Old 07-31-2007, 06:48 PM   #14
The Grand Wazoo
In Chicago, we pump the domestic water to the top floor, the building in the pic I posted is sixteen stories, and down feed the system, on buildings taller than 25 stories we use a PRV every fifth floor, but either way you have to provide air chambers or it is going to bang.
Old 07-31-2007, 06:51 PM   #15
I agree totally. Maybe physics are regional and differ in other states. I see they say water works differently in Fla.
Old 07-31-2007, 07:14 PM   #16
Licensed Electrician
knothole's Avatar
Trade: Licensed Electrictian
I've never heard of them in this area, but we don't even have a plumbing code in my county. That may be why. Also, I can't remember hearing a plumber saying anything about water hammer in this area.
Follower of Jesus Christ
knothole is offline
Old 07-31-2007, 09:01 PM   #17
Pro Plumber
Trade: Plumber
I still wipe my joints.
Old 07-31-2007, 09:10 PM   #18
The Grand Wazoo
I haven't done a wiped joint on a lead water service in years, but I think I still have the tools to do it, I might have to buy a new candle though.
Old 07-31-2007, 09:17 PM   #19
Pro Plumber
Trade: Plumber
I still wipe my solder joints, and I care how I do my job, but don't tell MechanicalDVR, he won't believe it's true cause we don't use air chambers here.
Old 08-01-2007, 07:37 AM   #20
kermmonk's Avatar
Trade: builder
Looks like I started something here. After much research I find out the mechanical arrestors work better than air chambers.
My plumber and I agreed to put mechanical arrestors at the washing machine and dishwasher. ( He still thinks I'm nuts! ) He says his own house has 3 1/2 baths, no air chambers and no arrestors. He says he has never heard any hammering.
I'll let you know what I hear when the house is done.
kermmonk is offline
