Journeyman Plumber
Trade: Plumbing
Air Admittance Valves - Have You Seen Them Fail Alot?
Im curious if you've seen many problems with air admittance valves? i always hear from the old timers that they always fail eventually, just curious what your experience has been with them?
The Grand Wazoo
Re: Air Admittance Valves - Have You Seen Them Fail Alot?
They aren't allowed by code here, but they get used occasionally, I have seen three of them that had the diaphragm rot and allow sewer gas in, I would expect this to be a common problem.
#3 | |
Pro Plumber
Trade: Plumber
Re: Air Admittance Valves - Have You Seen Them Fail Alot?Quote:
http://www.studor.com/approvals.htm |
Trade: Plumbing
I can't remember if I've seen one that failed, but then, our sewer gas isn't terrible here. I have one in an upstairs bath that has been in for quite a few years and I know it works because I can hear it. (Makes a sort of humming sound when I shut off the tap as air passes into it.)
I know that they can fail. But I also know that all the new manufactured homes in this area have them, and I don't get complaints.
There are no dumb questions - just a lot of inquisitive idiots. |
I get crawling around in attics every once in a while that have big one's in the attic. I can't speak to the frequency of failure, but I can say that they sometimes fail judging by the smell. Mind you, these are one's that are probably 20 years old or thereabouts. The occupants probably don't even notice the smell, since the attic itself is generally reasonably well ventilated.
Trade: plumber
A failed one could allow bugs as well as odors to enter your home.
#7 | |
Trade: HVAC
Maybe that's because the vents last longer than the homes. |
#8 | |
Retired Contractor
Trade: Plumber
I've smoke-tested lots of homes looking for those "mystery smells" no one could find. I have found quite a few failed Studor vents when they are installed below flood rim, under a lavatory or kitchen sink. Once a drain backs up and the admittance valve gets wet with soapy or greasy wastewater, you can bet it will fail. They "stick". |
| low voltage transformer for Zone valves. | kiffys | General Discussion | 3 | 12-07-2007 07:16 AM |
| Are air admittance valves legal in NJ?? | gnahthe | Plumbing | 2 | 07-04-2007 10:47 PM |
| Zone valves and transformers | mdshunk | HVAC | 3 | 05-13-2007 10:49 PM |
| What do you think about the new generation of interchangeable/upgradeable valves? | Mike Finley | Plumbing | 1 | 01-31-2007 11:56 PM |
| Air Admittance Valve question ...... | Vermonster | Plumbing | 20 | 09-11-2006 01:25 AM |
