Advice On Low Pressure Well Problem
Old 07-16-2007, 07:54 AM   #1
72chevy4x4's Avatar
I'm building a pole barn in the sticks and the home owner has a shallow 28' well which very low water pressure. He seems to think the well is dry, so I looked at it to give him my impressions (I need the water pressure for cleaning concrete tools soon). There was a valve going to the house, so I closed it and the pump never built pressure. After opening the port on the top, some pressure was evident, maybe 20psi and a little volume (he has a small 3-5gallon pressure tank). The front of the pump, the jet part, was very hot-so hot that I couldn't keep my hand there. Pretty sure it was running constantly.
Any idea on the cause? Is it possible the impellers get screwed up inside the housing and never generate enough pressure or volume to pull the water from the well? At 28', is that still a 'shallow' well-I seemed to recall 25' ratings for shallow pumps (does the extra 10% fry the pump since it works harder)?
72chevy4x4 is offline
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 04:41 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Problem with customer.. need advice 6stringmason General Discussion 32 01-15-2007 08:48 PM
Negative pressure problems Viper HVAC 5 01-03-2007 10:19 PM
Pressure switch problem?? burchis HVAC 13 03-29-2005 10:43 PM
