Add 2nd Hot Water Heater Or Replace Original With A Biger One?
Old 02-20-2004, 01:17 AM   #1
Mike F
Guest
Mike F's Avatar
Posts: n/a
Okay, the situation is we have added a big whirl pool tub, a vertical spa 2 person shower, and the 50 gallon gas hot water tank is just not cutting it.
Do I replace it with a 100 gallon tank or just get a 2nd 50 gallon tank? I don't even know if it is possible to add a second tank, how would that work? Would it be connected in series to the original, so that when the original tank draws down its supply of hot water, instead of fresh cold water refilling it, the 2nd tanks hot water would refill it? Instant hot water systems are out of the question.
Any serious pros or cons to doing either one?
Old 02-24-2004, 09:13 AM   #2
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Re: Add 2nd Hot Water Heater Or Replace Original With A Biger One?
i would not get another tank. Why not go the european way of domestic hot water generation. Takagi (GAS) or Stiebel Eltron (electric) make whole house Instant hot water heaters, eg, 3.5 gallons per minute at a 60degree temp rise. You will not waste energy keeping a tank full of water hot when not in use. America could save much eneergy if new homes were to use this type of system.
Old 02-24-2004, 11:09 AM   #3
Mike F
Guest
Mike F's Avatar
Posts: n/a
Why not tankless? As I said in my post they are out of the question.
They do not perform.
Old 02-26-2004, 10:07 PM   #4
softail's Avatar
Send a message via ICQ to softail Send a message via AIM to softail Send a message via MSN to softail Send a message via Yahoo to softail
Dont put all your eggs into 1 basket. I have installed hundreds of heaters for customers and many have chosen 2 of them. Make sure that the heaters are manifolded together, and 2 valves installed on each inlet and outlet. If 1 heater goes out, you can isolate the tank and still limp by on 50 gallons. As far as the tankless jobs,I am waiting 3 weeks now for a ignition contoll mod.that hasnt come in ( a Home Depot model) Sucks, the guy has been without hot water for all this time
Ups to you tho !
softail
softail is offline
Gas water heater with timer on it? rhinoguy Plumbing 1 06-10-2010 11:11 AM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Expansion tank on water heater Teetorbilt Plumbing 5 04-17-2006 01:53 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
