600' Water Line
Old 05-01-2009, 09:32 AM   #1
Wasting Time
Knighton's Avatar
600' Water Line
A friend of mine has an old farm and is planning on building a house. The Parish (county) he lives in has municipal water throughout, so he can tie into that water line. The house he's building is 600' off the road. His question was what size line does he need to run from the main to his house? He's also got a shop that needs water run to it for a sink and a couple of spigots. The shop will be adjacent to the house. Any suggestions would be greatly appreciated.
Knighton is offline
Old 05-01-2009, 04:08 PM   #2
jmic's Avatar
Re: 600' Water Line
Any idea what kind of pressure at the main? What's the property like? Uphill, flat, downhill?
We recently did a house where the town water main didn't have enough pressure once the water reached the house. Had to install a booster pump.
Joe
jmic is offline
The Following User Says Thank You to jmic For This Useful Post:
Knighton (05-04-2009)
Old 05-02-2009, 12:25 AM   #3
Moderator
Double-A's Avatar
Re: 600' Water Line
Several things are going to have to be taken into consideration before a question like that can be answered properly.
What size meter will the water purveyor set?
Are there any back flow device requirements at the meter?
What is the delivery pressure from the meter?
Is there any elevation change between the meter and the house?
is there any elevation change between the house and the shop?
Is the 600' run straight or will it have to follow a winding path or make any turns?
Have your friend contact a plumber in the area and also talk to the water purveyor as well.
New York Times, July 20, 2006
Double-A is offline
Old 05-04-2009, 05:29 PM   #4
Wasting Time
Knighton's Avatar
Re: 600' Water Line
Double A -
Thanks for the response. I figured it wouldn't be a simple answer, but if it were I thought I'd help him out. Looks like a plummer is the only real way to go on this one! Far too many variables.
Knighton is offline
Old 05-04-2009, 10:54 PM   #5
Railman's Avatar
Trade: Railing
Re: 600' Water Line
Knighton,
I ran one about that long once, but it was 23 years ago, & I forgot how to do the calcs.
Try this for starters:http://www.freecalc.com/fricdia.htm
Joe
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Knighton (05-06-2009)
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 08:18 AM
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 10:41 PM
operating a water source unit with no water? 3lbfinishhammer HVAC 3 12-26-2008 08:19 AM
Need advice on high pressure water mains. MC Excavating Excavation & Site Work 25 12-13-2008 08:35 PM
water condensation/ice and watershield altonarch Roofing 5 11-23-2008 10:51 PM
