3 Inch Pvc Pipe To Sump Pump
Old 12-07-2008, 04:47 PM   #1
shiznit's Avatar
Trade: Flooring/Basement finishing
1st of all love the site,
I am about to carpet a basement floor (no subfloor), there is a 3 inch pvc pipe that leads to the sump pump. It's about 4 feet into the side of the living room. 15 or so feet away from the sump pump. I made sure it went there as well. My question is or how do I cover it up. Do I cap it, use a perferated cap or cut a hole in the carpet and use a brass or metal drain cap. I have not seen this in the few years I've been doing basements.
Thanks for any info.
Steve
shiznit is offline
Old 12-07-2008, 06:09 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: 3 Inch Pvc Pipe To Sump Pump
Pictures
Ron The Plumber is offline
Old 12-07-2008, 08:39 PM   #3
shiznit's Avatar
Hope these help
3 inch pvc pipe to sump pump-sump-pump-pvc-002.jpg   3 inch pvc pipe to sump pump-sump-pump-pvc-003.jpg
shiznit is offline
Old 12-07-2008, 08:42 PM   #4
Handle It!
MALCO.New.York's Avatar
Hey "The Shiiit"! (really poor name....But I digress........)
Look what I found to aid you in your endeavors..........
http://www.contractortalk.com/f44/
WELCOME to ContractorTalk.Com
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-07-2008, 09:37 PM   #5
shiznit's Avatar
I guess there's always one bad seed in the bunch, but thanks for you worthless post jack&%@
shiznit is offline
Old 12-07-2008, 09:39 PM   #6
Handle It!
Yeah!!!!! Thatt'll get you REAL far here!!!
Old 12-07-2008, 09:41 PM   #7
mdshunk's Avatar
That's the radon inlet. Do not cap it. It is scientifically designed and calibrated to kill the dwelling's occupants in a set period of time.
mdshunk is offline
Old 12-07-2008, 09:54 PM   #8
threaderman's Avatar
Trade: Plumbing & Gas Contractor
The only thing my man Malco was saying was "hey,why don't you introduce yourself".Now you can introduce yourself to the do-it-yourself forum.This ain't it.
threaderman is offline
Old 12-07-2008, 09:59 PM   #9
Handle It!
I was a bit "Sideways"............... But I AM good at weeding them out!!!!!
Old 12-07-2008, 10:28 PM   #10
The Grand Wazoo
KillerToiletSpider's Avatar
Just guessing from the depth that one is set for three years four months and 26 days.
Make sure they aren't real slow payers.
KillerToiletSpider is offline
Old 12-07-2008, 11:01 PM   #11
Pro Plumber
Trade: Plumber
I'll help you since no one else wants to, it's my new way of giving answers, so you want to cap that 3" line, you talking about the line done inside the sump pump?
Old 12-08-2008, 08:43 PM   #12
cleveman's Avatar
Trade: custom home building
You guys don't always play well in the sandbox.
Just shove some stuff down that line to the elbow and fill it with mortar. Hard to say why it was there-maybe someone's idea of a floor drain?
cleveman is offline
Old 12-17-2008, 02:13 PM   #13
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
It looks like a makeshift floor drain. My guess is that the basement flooded at some point and maybe the sump pump was not at the lowest point (as it should) and maybe someone decided to to run a pipe from there (the pressumed lowest point) to the drain. If that is the case then I would agree with cleveman to block it since you are putting carpet and it's assumed that basement will not flood, ruining the carpet as well. It is not a Radon pipe but you might have already noticed that Mr. MdShunk was joking.
A.D. Const is offline
Old 12-17-2008, 03:09 PM   #14
Vagitarian's Avatar
Trade: Plumbing
Just stuff an oversized ball of newspaper in it leaving a couple of inches from the top. Fill with mortar or plaster of paris.
Vagitarian is offline
Old 12-17-2008, 03:24 PM   #15
mickeyco's Avatar
Trade: Squirrel Handler
Why the hell would you do that, they make flush fitting expandable plugs.
mickeyco is offline
Old 12-17-2008, 09:01 PM   #16
cleveman's Avatar
Everybody has some newspaper and mortar lying around. They is who?
cleveman is offline
Sump Pump runs often robertc65 Plumbing 13 03-23-2010 08:49 PM
Sump Pump questions WhitlockConst Plumbing 3 08-17-2008 12:32 PM
Finishing carpet around sump pump TylerCoe11 General Discussion 7 07-09-2008 07:21 AM
Three inch drain pipe. AbeBarker Plumbing 28 12-31-2007 08:01 PM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
