#21 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ?
I told you why.
#22 | ||||
Fentoozler
Re: 3" Or 4" ?Quote:
I'm sure you think you did..... ![]() I never asked what is "code". Previously, 4" was all the rage...nowadays, 3" is allowed...why? I'm pretty sure the code wasn't written to save someone a few bucks on material.
#23 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ? |
#24 | |
Fentoozler
#25 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ? |
#26 | |
I have excavated and assisted the install of hundreds of sewer laterals, at some point the code changed to require 3" pipe as opposed to 4" pipe. When I asked about this change it was explained that with the utilization of the (now mandated) low flush toilets it was found that the volume of water was not sufficient enough (in a 4" pipe) to carry the "solids" down the pipe. The use of a smaller (3" pipe) would allow the "debris" to be carried more efficiently to it's destination, with out any debris being left behind. It sounded like a reasonable explanation then, and still makes sense to me now. It's all about the float factor.
| The Following User Says Thank You to tgeb For This Useful Post: | Celtic (09-23-2009) |
#27 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ?
See I knew your buddies had the answer, who needs a pros view.
#28 |
Trade: Construction
Re: 3" Or 4" ?
I dont think i have ever seen cast iron soil pipe less than 4" and thats the reason all UK toilets use 4" connections as i guess it's a standard size setup in UK like pic 1. But because the US toilets use a bottom waste like in pic 2 and have a far smaller outlet perhaps they allowed use of 3" and fully explains why they block up so much.
pic 1 ![]()
#29 | ||
Fentoozler
W/o offering ANY sort of explanation
#30 |
Fentoozler
Re: 3" Or 4" ?
At least he gave an answer with some sort of explanation behind it....which is almost verbatim what the inspector had mentioned to me.
#31 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ? |
#32 |
Fentoozler
Re: 3" Or 4" ?
So now your panties are all in a knot
because you couldn't put a thought to pen and paper? ...and that's my fault I don't just follow along with blind obedience?
#33 |
The Grand Wazoo
Re: 3" Or 4" ?
Chicago code does not allow three inch for a WC below ground, or when there are more than two WC's on the stack above ground.
#34 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ? |
#35 |
Fentoozler
Re: 3" Or 4" ?What good is code if you don't understand it?
#36 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ? |
#37 | |||
Fentoozler
Excuse me?????? Quote:
Ron...you have should bowed out and stayed out...... you tossed out more unwarranted snide comments and smileys than was even remotely necessary. Now all of a sudden, I am disrespecting you? I don't think so. If anything, not only did you disrespect me and yourself, but also your entire trade. It's a simple question of THEORY. Why did the code change? Was one way better than the other? Why? You simply couldn't answer it. There is no shame in that. I don't know all things electrical. If I'm wrong, I admit it. It's not a big deal....I end up learning something. Now you want to make this personal. Have it your way - which is the way it seems you wanted it from the start.
| The Following User Says Thank You to Celtic For This Useful Post: | Ron The Plumber (09-23-2009) |
#38 |
Pro Plumber
Trade: Plumber
Re: 3" Or 4" ?
I answered it, but your the plumber not me, have fun
#39 | ||||
Pro Plumber
Trade: Plumber
Look at all those rolling eyes. |
#40 |
Trade: Excavation, land clearing, sewer/water
Re: 3" Or 4" ?
I'm not a pro plumber but I have done lots of excavations for septics and sewers.... My take on this is that the 3'' pipe works better in-as-much as the smaller diameter pipe doesnt allow the liquid and solids to separate as much/quickly... Dunno if thats right but it sounds plausible. Thats my story, I'm stickin' to it....
| The Following User Says Thank You to Williams Ex Co For This Useful Post: | Ron The Plumber (09-24-2009) |
| j-channel with 3" deep pocket. | thesidingpro | Windows, Siding and Doors | 20 | 07-10-2011 09:23 PM |
| Extending 4" studs to 5 1/2" | Danno6102 | Carpentry | 18 | 05-29-2009 07:38 PM |
| Is this in Your area yet??? 4" sharkbites ???? | Driftwood | Plumbing | 11 | 09-25-2008 06:59 PM |
| Tapping into a 4" PVC Drain | Michael S | Plumbing | 3 | 08-11-2008 11:45 PM |
| 3" verse 4" painting siding, and boxing | Dave Mac | Painting & Finish Work | 2 | 12-11-2007 04:32 PM |
