Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Plumbing
Old 09-21-2009, 04:24 PM   #1
Fentoozler
Celtic's Avatar
3" or 4" ?
Which is "better" for a typical SFH's closet flange to the main DWV?
In talking with a local plumbing inspector, he offered his "opinion"....I now ask the pros for their opinions.
Celtic is offline   Reply With Quote
Old 09-21-2009, 04:31 PM   #2
Trade: Construction
In the UK we was always told to use no less than 4" soil pipe but i see a lot of 3" over here and it seems to do the job. Esp now that the toilets are using a lot less water to flush. But i do notice the toilets over here block up a lot more than in the UK.
BCConstruction is online now   Reply With Quote
Old 09-22-2009, 10:46 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
SFH's?
Ron The Plumber is offline   Reply With Quote
Old 09-22-2009, 10:55 PM   #4
Fentoozler
Celtic's Avatar
Originally Posted by Ron The Plumber View Post
SFH's?
Single
Family
Home
s
Old 09-22-2009, 10:58 PM   #5
Pro Plumber
Trade: Plumber
3" Always
Old 09-22-2009, 11:02 PM   #6
Fentoozler
Celtic's Avatar
Why?
I generally see 4" cast with lead elbows all over.
Old 09-22-2009, 11:07 PM   #7
Pro Plumber
Trade: Plumber
For new installs 3" ABS or PVC.
Old 09-22-2009, 11:10 PM   #8
Fentoozler
Celtic's Avatar
...why not 4" ABS or PVC?
Old 09-22-2009, 11:15 PM   #9
Pro Plumber
Trade: Plumber
Why run 4" when code allows 3" for up to 3 toilet till you need to be 4", cost less to run 3" then 4"
Old 09-22-2009, 11:19 PM   #10
Fentoozler
Celtic's Avatar
...because that doesn't really answer the question:
Cheaper is not always "better".
Bare code minimum is not always "better".
Old 09-22-2009, 11:21 PM   #11
Pro Plumber
Trade: Plumber
Sorry you can't accept my answer I shall bow out.
Old 09-22-2009, 11:23 PM   #12
Fentoozler
Celtic's Avatar
It's not the I can't accept your answer....I just won't accept it w/o some theory or logic behind it.
Simply because "it's code" doesn't sit well with me.
Old 09-22-2009, 11:24 PM   #13
Pro Plumber
Trade: Plumber
Waste water flows just a well inside 3" as it does inside 4", that sounds logical to me.
Old 09-23-2009, 05:48 AM   #14
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
It's not based on number of toilets, but quantity and size of meals. Do you attend a lot of all-u-can-eat buffets? Fast food? Corn?
Better opt for the 4" to be on the safe side.
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is offline   Reply With Quote
Old 09-23-2009, 07:36 AM   #15
Trade: GC/Remodeling
I'm not a plumber, but I have stayed at Holiday Inn, and used a lot of toilets....
Given the same toilet, 3" will have a faster flow than 4"...
Gets 'stuff' movin down the line
What is larger than 3" that will go through the trap in the WC?
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 09-23-2009, 07:50 AM   #16
The Old Master
Trade: Plumbing & Heating
DFU's Drainage fixture units goveren the piping size.
Read the code book! Usually on residential work the I.P.C. will allow 2 bathroom groups on 3" PVC/ABS, No/Hub cast iron, copper tube. More fixtures (ie: another powder room or a mud bath) the the piping from that point of connection to the main must be 4" to the exit from the building. Usually 4" is required for the house sewer at least in the code we follow.
Bill Parr L.M.P. www.parrsplumbing.com
for a job that's up to "PAR"
Plumber_Bill is offline   Reply With Quote
Old 09-23-2009, 07:37 PM   #17
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
To the OP:
3" lateral drain with 4" riser is the best.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline   Reply With Quote
Old 09-23-2009, 07:58 PM   #18
Fentoozler
Celtic's Avatar
<~~~~ Look at my "trade".
The Following User Says Thank You to Celtic For This Useful Post:
CookeCarpentry (09-24-2009)
Old 09-23-2009, 08:02 PM   #19
Patrick's Avatar
just make sure the pipe dumps into your neighbors pond
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline   Reply With Quote
Old 09-23-2009, 08:02 PM   #20
Fentoozler
Celtic's Avatar
Originally Posted by Plumber_Bill View Post
Read the code book!
In case you missed it, I'm not interested in what the book says....I'm interested in the theory behind it.
Extending 4" studs to 5 1/2" Danno6102 Carpentry 18 05-29-2009 06:38 PM
j-channel with 3" deep pocket. thesidingpro Windows, Siding and Doors 11 11-07-2008 06:13 PM
Is this in Your area yet??? 4" sharkbites ???? Driftwood Plumbing 11 09-25-2008 05:59 PM
Tapping into a 4" PVC Drain Michael S Plumbing 3 08-11-2008 10:45 PM
3" verse 4" painting siding, and boxing Dave Mac Painting & Finish Work 2 12-11-2007 04:32 PM
