2 Cast Iron Through Concrete
Old 02-27-2018, 08:16 PM   #1
djfremen's Avatar
Trade: General
Rewards Points: 12
Hey Gang,
I have a few casts going into an old laundry room I want to convert to a livable space. There are two inch cast iron (white pipes) and going to a lead and oakum bell inside the concrete. Thinking about trenching across the room if these actually go to a bigger 3" below... Anyone see this before? Why would they vent this way? Any advice how to explore this without breaking the cast bells?
thanks mucho,
djfremen is offline
Old 02-27-2018, 11:13 PM   #2
daffysplumbing's Avatar
Trade: plumber
Rewards Points: 598
Re: 2 Cast Iron Through Concrete
Every 2 inch drain eventually connects to a 3 inch or 4 inch sewer pipe. Every toilet has either a 3 or 4 inch sewer pipe. Locate the nearest toilet and determine what direction the pipe from the toilet runs to the city's sewer or septic system. When plumbers run cast-iron drains they always run the shortest distance to get out from underneath the house slab because cast-iron piping is expensive to run. Plumbers don't usually run sewer piping underneath foundations in a straight line because going diagonally takes more pipe. Then, when they get outside the foundation wall the plumbers will run the sewers diagonally to get to the connection at the property line or septic tank.
It looks like the existing plumbing was modified after the initial installation, fixtures were relocated, or the job was bootlegged. It looks like there may have been a floor drain near the laundry sink and they is why there are 2 vent pipes.
daffysplumbing is offline
The Following User Says Thank You to daffysplumbing For This Useful Post:
djfremen (02-28-2018)
Old 02-28-2018, 12:17 AM   #3
djfremen's Avatar
Trade: General
Rewards Points: 12
Thanks Daffys Plumbing. Thats great information. Indeed, right off camera there is the floor drain (hence the sloping concrete pour).
As far as workflow, would you recommend drilling pilot holes with a sds rotary hammer or scoring it with a carbide saw? Its pretty fragile work for a jack hammer around vents, right?
djfremen is offline
Old 02-28-2018, 07:41 AM   #4
Trade: plumber
Rewards Points: 598
If you are looking for the sewer pipe to install a larger pipe for a toilet I would not follow the 2 inch drain pipe. If that is a 2-story house there must be a sewer pipe going from a toilet into the concrete slab and that is the pipe I would try to locate and follow. For really old concrete, you we often use a 5 lb hammer or a sledge hammer. Looking at those old pipes it would probably be a blessing if you mistakenly break them and with all the plastic pipes and fittings today it is easy to replace drains. If I was keeping the house I would replace all the drains under the concrete slab all the way to outside the house.
Old 02-28-2018, 11:02 AM   #5
djfremen's Avatar
Trade: General
Rewards Points: 12
Good advice. Thanks. There isnt a toilet at the basement level unfortunately. The soil stack goes up 2.5 stories and likely exits the house by the 2 pipes (I hope). The backyard slopes so it cant travel any other direct. Ill post again when I find something.
djfremen is offline
Removal of shower flange from Cast iron pipe Dukelewis8719 Plumbing 13 05-24-2016 09:45 PM
Cast iron bathtub with end apron Waynegc Plumbing 6 08-28-2011 05:49 PM
Cast Iron Tub antnepi Construction 16 07-27-2010 08:21 PM
ABS to cast iron? pzeiler Plumbing 9 06-09-2010 09:57 AM
cast iron heating element/radiator builditright Plumbing 1 10-21-2009 01:31 PM
