1” AquaPEX Through Ceiling Joists - Plumbing - Contractor Talk
Old 02-18-2018, 01:40 PM   #1
djfremen's Avatar
Trade: General
Rewards Points: 12
Hey Gang,
I’m running a 1” cold water Pex line through a basement ceiling to replace a buried, sediment clogged galvanized supply. The basement is going to be a livable space (not drop ceiling).
What size hole should I bore in the joists? Should I worry about expansion noise and plan a larger hole accordingly?
Thanks much,
djfremen is offline
Old 02-18-2018, 04:24 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,232
Re: 1” AquaPEX Through Ceiling Joists
I would use the 1" tubing insulators which use a 1 3/8 hole if it was me.
Randy Bush is online now
Old 02-20-2018, 05:24 AM   #3
builditguy's Avatar
Rewards Points: 428
That is an interesting question. I don't have an answer.
Aren't you glad I replied to this.
My point: I have been to more than one house, where they complain about the copper noise. The copper pipes expand and contract as the hot water goes through them.
Personally, I like Pex. I would say, drill the hole a little larger and go with it. It may make noise, but only time will tell.
builditguy is offline
Old 05-26-2018, 12:54 PM   #4
RLH_CT's Avatar
Trade: GC/Finish work
Rewards Points: 54
Agree with Randy - no muss, no noise, nice clean install and next to no $'s to do it.
RLH_CT is offline
Old 05-31-2018, 01:19 PM   #5
AustinDB's Avatar
Rewards Points: 840
Aren’t there provisions for an expansion loop after a long length?
AustinDB is online now
Partition wall under drop ceiling LooseScrews Commercial Construction 29 12-30-2017 08:00 PM
Load Bearing Walls Running Perpendicular To Ceiling Joists? Antropovsky Architecture & Design 17 12-14-2014 11:42 PM
installing a Hunter ceiling fan on a concrete ceiling dale rex Electrical 24 07-17-2012 06:12 PM
Drop ceiling space between grid & joists? jimb317 Carpentry 7 04-09-2010 06:06 PM
