1/2" Vs 3/4" Hot Water Line
Old 02-07-2012, 10:12 AM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,460
Re: 1/2" Vs 3/4" Hot Water Line
Originally Posted by Cole82 View Post
All the shutoffs are in one location and less fittings. Just the supply line connection and the manifold connection. The topic of this thread as well I have always been told that 1/2" line gets hot water faster that a main run with branches. Pex pipe is cheaper than fitting to connect to main line. Other than that I don't know that's why I asked.
Cole
Yes and no...
I'd be hard pressed to think the savings of not buying 3/4" T's would be more than buying all that extra 1/2 pipe and shut-off valves.
Think about this, you take a dump, then go to wash your hands with hot water, now the trunk is hot, you get hot water right away at the shower instead of draining long 1/2 inch lines for each fixture.
Inner10 is online now
Old 02-07-2012, 05:38 PM   #22
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,049
I did for a moment. Sounded like you had the commode hooked to the hot water line.
Tinstaafl is online now
mehtwo (03-03-2012)
Old 02-07-2012, 05:48 PM   #23
Inner10's Avatar
I'm not that rich!
...But I do wash my hands with warm water.
Old 02-07-2012, 06:08 PM   #24
Working
Cole82's Avatar
Rewards Points: 2,276
Yes and no...
There are no extra shut off valves the valves are on the manifold built into it.
You are assuming the trunk/main line is warm but after sitting idle for 10 hours a normal work day. It isn't very warm anymore. Of coarse if you have a stay at home wife she could be doing laundry or dishes through out the day keeping it warm. We will say it's cold now though after the 10 hours. You go to wash your hands after that monster poop you speak of. Now you have to drain that large main line before you get warm water. With the manifold setup it's only a 1/2" line instead of 3/4" or even 1".
Not trying to argue just wondering as the branch setup is unheard of here. I was actually trying to remember the last one I saw on a new house and I think it was 98. I remember back in the late 80's early 90's they were using manifolds in the new development behind our house.
Cole
The boss of awesome
Cole82 is offline
Old 02-07-2012, 06:23 PM   #25
Inner10's Avatar
Must be a regional thing, only time I've ever seen manifolds being used for potable water was when it was a DIY job and the homeowner though it was better for some reason. Never seen a real plumber do it that way.
Cole82 (02-07-2012)
Old 02-07-2012, 06:31 PM   #26
Working
Cole82's Avatar
Must be a regional thing.
On a side note. If I ran hot water to my toilet would it keep the seat warm?
Cole
The boss of awesome
Cole82 is offline
Old 02-07-2012, 10:51 PM   #27
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,868
Cole
No, but it will keep the tank from sweating in the summer time.
KillerToiletSpider is online now
Old 02-08-2012, 06:37 AM   #28
TimNJ's Avatar
Rewards Points: 2,694
Cole
When I worked on a military base there was always some plumber who would end up hooking up a toilet to the hot water line.
Gave new meaning to "take a steaming sh**".
The janitors thought it was great. They could sanitize the toilet just by flushing it once or twice.
TimNJ is offline
Old 02-08-2012, 06:38 AM   #29
TimNJ's Avatar
Tin this link covers manifold design benefits over traditional systems.
http://www.huduser.org/portal/public...sign_guide.pdf
Flow Rate ft/sec
GPM 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 2”
0.2 0.67 0.36 0.25 0.18 0.11 0.07 0.05 0.03
0.3 1.00 0.54 0.37 0.27 0.16 0.11 0.08 0.05
0.4 1.33 0.72 0.50 0.36 0.22 0.15 0.11 0.06
0.5 1.67 0.91 0.62 0.45 0.27 0.18 0.13 0.08
0.6 2.00 1.09 0.74 0.54 0.33 0.22 0.16 0.09
0.7 2.33 1.27 0.87 0.64 0.38 0.26 0.18 0.11
0.8 2.67 1.45 0.99 0.73 0.44 0.29 0.21 0.12
0.9 3.00 1.63 1.12 0.82 0.49 0.33 0.24 0.14
1.0 3.33 1.81 1.24 0.91 0.55 0.37 0.26 0.15
1.1 3.67 1.99 1.36 1.00 0.60 0.40 0.29 0.17
1.2 4.00 2.17 1.49 1.09 0.66 0.44 0.32 0.18
1.3 4.34 2.35 1.61 1.18 0.71 0.48 0.34 0.20
1.4 4.67 2.53 1.74 1.27 0.76 0.51 0.37 0.22
1.5 5.00 2.72 1.86 1.36 0.82 0.55 0.40 0.23
1.6 5.34 2.90 1.98 1.45 0.87 0.59 0.42 0.25
1.7 5.67 3.08 2.11 1.54 0.93 0.62 0.45 0.26
1.8 6.00 3.26 2.23 1.63 0.98 0.66 0.47 0.28
1.9 6.34 3.44 2.36 1.72 1.04 0.70 0.50 0.29
2.0 6.67 3.62 2.48 1.81 1.09 0.73 0.53 0.31
2.5 8.34 4.53 3.10 2.27 1.36 0.92 0.66 0.38
3.0 10.00 5.43 3.72 2.72 1.64 1.10 0.79 0.46
3.5 11.67 6.34 4.34 3.18 1.91 1.28 0.92 0.54
4.0 7.24 4.96 3.63 2.18 1.47 1.05 0.62
4.5 8.15 5.58 4.08 2.46 1.65 1.19 0.69
5.0 9.05 6.20 4.54 2.73 1.84 1.32 0.77
6.0 10.86 7.44 5.44 3.28 2.20 1.58 0.92
7.0 8.68 6.35 3.82 2.57 1.84 1.08
8.0 9.92 7.26 4.37 2.94 2.11 1.23
9.0 11.16 8.17 4.91 3.30 2.37 1.39
Great link there.
TimNJ is offline
Old 02-08-2012, 06:42 AM   #30
TimNJ's Avatar
Originally Posted by Tinstaafl View Post
Leaving aside the overall volume of flow, at what point is it better in terms of hot water NOW at the faucet to use a 1/2" line to take advantage of the higher velocity of flow? Does that question make any sense?
How is your layout set up.
When I built my place I had my h/w in my mechanical room. After living in the house for a while I ended up relocating it so it was closest to the point of where I actually used most of my h/w. Made a big difference.
TimNJ is offline
Old 02-08-2012, 06:45 PM   #31
Capra aegagrus
Tinstaafl's Avatar
That certainly would, no doubt about it.
But it's often not practical to do that for various reasons, and that's when this question comes into play. In the situation that prompted the OP, my buddy ran 3/4" cold water lines, but used 1/2" for hot--based on the theory that the HO wouldn't have to wait as long for hot water at the faucet. The inspector shot him down and made him change it to 3/4".
Old 02-08-2012, 07:01 PM   #32
Working
Cole82's Avatar
I just tried finding anything that requires a 3/4" line and the only thing I could find are flushing rim sinks.
That is looking at IPC table 604.5
Unless it's a local amendment I would have asked him to show you the code.
Cole
The boss of awesome
Cole82 is offline
Old 02-08-2012, 07:06 PM   #33
Capra aegagrus
Tinstaafl's Avatar
Yeah, I know. But it's the same inspector for framing, plumbing, electric etc etc. Easier to just say yassa, Massa.
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Ben81 (02-09-2012), Cole82 (02-08-2012), mehtwo (03-03-2012)
Old 02-08-2012, 09:30 PM   #34
Chris
PowerWash's Avatar
Trade: Pressure Washing
Rewards Points: 192
And that is the only thing about building new houses I do not miss! Inspectors in our area are assigned a house and they inspect it from start to finish. Gotta play the game.
Pressure Washing Charleston SC - Pressure Washing Summerville SC Pressure Washing: Charleston, Summerville, West Ashley, Mt. Pleasant, Daniel Island, SC - Pressure Washing
PowerWash is offline
Old 02-09-2012, 03:05 PM   #35
Ben81's Avatar
Trade: plumber
Recirc line 1/2" dia with the pump being 1/2" dia as well. I've seen too many installations with the 3/4" pump and it eventually eating the copper in the house. That type of pump is made for the commercial end of things. This pump is only 1/250th of a hp and has the option to run continuously or on a timer. Timing wise depends where you would hook your recirc line up to. Some instances you can't always get your recirc line teed off right in the cabinet by the affected fixture but put it as close as you can and insulate the recirc line
Ben81 is offline
Old 03-01-2012, 03:22 PM   #36
Jackfre's Avatar
Trade: General, plumbing, HVAC, solar
There are good reasons to get down to 1/2", from the 3/4" main, as soon as possible. You have to take pressure drop into consideration but I've gone thru this a lot. I represented a major tankless manuf. Tankless will not make hot water until the tap is opened. Proximity to the point of use is a consideration in the installation. Given that the cross sectional area of 1/2" is .19 sq in and 3/4" is .44, there is over twice the vol to possibly waste prior to getting hot water. A properly sized 1/2 line makes sense. Also, you have to consider the flow rate of the particular fixtures you are selling.
On our home in MA. that we sold last year, I had a tankless water heater for 12 yrs. It was right under the kitchen sink. I remodelled the bathrooms and re-installed the tankless on the other side of the basement using the same piping with 3/4 feeding across to the front of the house where the bathrooms were located. It took forever to get hot water at the kitchen sink as I had to dump all that 3/4". I explained to my wife the changes. She then explained to me, not exactly what the changes were going to be, but what the end result would be. After 38 yrs I understand her when she speaks in this way. Especially so when she is correct. I ran a 1/2" line direct to the kitchen sink, reducing the delay and dump vol. All good!
Jackfre is offline
Old 03-02-2012, 08:23 AM   #37
bob_cntrctr's Avatar
Trade: property manager & renovator
Could someone please explain this? A "3/4" pump" (never seen a pump with a 1/2" fitting - but I'm thinking of well pumps) somehow will cause the copper to be corroded?
bob_cntrctr is offline
Old 03-02-2012, 09:32 AM   #38
txgencon's Avatar
Rewards Points: 430
Who washes their hands just before getting in the shower?
On another note:
100 feet of 3/8" water line will have 0.57 gallons of water
100 feet of 1/2" water line will have 1.02 gallons of water
100 feet of 3/4" water line will have 2.29 gallons of water
txgencon is offline
Old 03-02-2012, 11:17 AM   #39
Inner10's Avatar
I always wash my hand's after wiping my ass...but that's just me.
I'm still surprised to see that running dedicated pipes is common practice in some areas. A popular way lately has been to have a trunk and branch setup with a tankless water heater and a re-circ pump on a timer.
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
BWFS (03-02-2012), mehtwo (03-03-2012)
Old 03-02-2012, 06:01 PM   #40
txgencon's Avatar
Rewards Points: 430
You should try using toilet paper and/or wet wipes.
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
DavidC (03-03-2012)
Nails in Water Line JMK General Discussion 62 01-04-2012 01:05 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 10:54 PM
Could water heater be overheating and overflowing? bob_cntrctr Plumbing 18 03-17-2009 07:39 PM
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 09:41 PM
water line question amurrell Plumbing 15 05-20-2008 08:44 PM
