Paper Corner Bead And Setting Compounds
Old 05-11-2007, 10:33 PM   #1
James Brothers's Avatar
Trade: drywall remodeling new con.
I need to get some corner bead on in a hurry. My first idea was to use vinyl with spray glue, then two coats of sheet rock 45 and a final coat with all-purpose. I’ve heard that you should not use setting compounds with vinyl bead. Plus it’s on a low soffit in the middle of a room. So it’s only a matter of time before someone hits it with something and breaks a chunk out if it!
My other idea was to use paper bead set with sheet rock 45 and coated with all-purpose. I don’t know how it would hold up, but it seems that it would be a lot more durable and possibly faster.
Hoping to find out by tomorrow. Thanks!
James Brothers is offline
Old 05-12-2007, 09:00 AM   #2
Re: Paper Corner Bead And Setting Compounds
I posted this in the wrong place didn’t I.
Old 03-16-2008, 02:51 PM   #3
Tapingfool's Avatar
Trade: spackler--for life it seems like I can never get away from it as there is always work somewhere!!
I guess it is too late for me to reply!! sorry..hope it worked out..
Tapingfool is offline
Old 03-16-2008, 02:53 PM   #4
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
why not use a metal corner bead?
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 03-28-2008, 02:05 PM   #5
Brocktologist llc.
Brockster's Avatar
Trade: drywall
and use 20minute.
Brockster is offline
Old 03-28-2008, 07:18 PM   #6
oldrivers's Avatar
Trade: drywall applications
Why cant you use setting compound with plastic beads?? im sure you meant plastic and not vinyl. I always use setting compound to lock in plastic beads setting compund sticks to just about any surface better than any other type of mud. it will stick to the bottom of a plastic bucket filled with water.
oldrivers is offline
Old 03-28-2008, 07:34 PM   #7
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
I've never heard that you can't use setting compound w/ plastic either. The only thing I can think of, is the heat generated could possibly warp the plastic. I've never had a problem w/ it though.
Sir Mixalot is offline
Old 05-23-2010, 11:14 AM   #8
scott67c's Avatar
Trade: union dyrwall finisher
paper works great i use it all the time
scott67c is offline
Old 05-24-2010, 11:31 PM   #9
jmr's Avatar
Trade: drywall contractor
use paper.. use 20 min, don't coat over it with regular mud if damp or wet.. also dont use all purpose to coat, use regular plus 3..
jmr is offline
Old 01-10-2012, 10:51 PM   #10
Drywall & Tape
PrecisionTaping's Avatar
Trade: Drywall, Taping & Stucco
By the time it took you to get to your computer and type this up you could have had your bead on and 1st coated bro.
Im sure you know vinyl is a type of plastic.
PrecisionTaping is offline
Tape/mud drying process (accelleration) andrewtlocke Drywall 11 03-10-2005 10:31 AM
