Corkscrew Shaped Skylight Tunnel.
Old 05-25-2009, 10:59 AM   #1
bob_cntrctr's Avatar
Trade: renovator
Gentlemen,
This will be my first time posting pics. Done mostly in response to this thread:
http://www.contractortalk.com/f49/curved-stairs-58473/
Similar story here - the skylight is the width of one rafter, but the opening in the ceiling is to be two rafters wide. That means that one of the tunnel wals has non-parallel top and bottom, creating a corkscrew surface, like the bottom of the stairs in that thread. I hadn't thought of the metal stud trick, so it's framed in 2x4's but with the same idea - lots of breaks around the curve, fitted pieces, then smoothed with compound.
Note that this is done not in drywall but in Hardiboard. This skylight is directly over a shower in a cold climate - it's going to spend a lot of time covered in moisture, so the Hardi should resist that well.
With the angle between even neighbouring studs changing from top to bottom, the Hardi board had to bend to conform to the corkscrew shape. On these small sections, it bent just fine, so long as I used lots of screws to hold the edges flush. Even with that, though, it was impossible to make the face of the studs do the same without some fancy milling, so some edges did stick up more than I'd like and it required several passes with the compound to get the surface smooth.
Lots of fun figuring the cut angles for the framing.
Corkscrew shaped skylight tunnel.-img_1692.jpg   Corkscrew shaped skylight tunnel.-img_1694.jpg   Corkscrew shaped skylight tunnel.-img_1697.jpg
bob_cntrctr is offline
Old 05-25-2009, 11:00 AM   #2
Trade: renovator
Re: Corkscrew Shaped Skylight Tunnel.
Next steps.
Corkscrew shaped skylight tunnel.-img_1704.jpg   Corkscrew shaped skylight tunnel.-img_1709.jpg   Corkscrew shaped skylight tunnel.-img_1713.jpg
Old 05-25-2009, 11:01 AM   #3
Trade: renovator
And next again.
Corkscrew shaped skylight tunnel.-img_1714.jpg   Corkscrew shaped skylight tunnel.-img_1880.jpg
Old 05-25-2009, 11:01 AM   #4
Trade: renovator
And all done
Corkscrew shaped skylight tunnel.-img_1887.jpg   Corkscrew shaped skylight tunnel.-img_1889.jpg
Old 05-25-2009, 11:12 AM   #5
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Why? Because I can, thats why.
willworkforbeer is offline
Old 05-25-2009, 11:53 AM   #6
Rockhound's Avatar
Trade: Drywall Hanger
Send a message via Yahoo to Rockhound
Awesome. I hope the pay was awesome too!
Rockhound is offline
Old 05-26-2009, 11:48 PM   #7
sparehair's Avatar
Trade: Painting, flooring
Originally Posted by bob_cntrctr View Post
And next again.
Very nice work. did you caulk the seams between the hardi before you seamed em? what kind of compound did you cover with, anything besides normal joint compound?
sparehair is offline
Old 05-30-2009, 02:45 PM   #8
Trade: renovator
Nope.
..what kind of compound did you cover with, anything besides normal joint compound?
And, Nope.
Old 05-31-2009, 09:24 AM   #9
General Contractor
greg24k's Avatar
Is this what customer wanted and requested to be done this way?
Gentlemen,
greg24k is online now
Old 05-31-2009, 10:51 AM   #10
curapa's Avatar
Trade: Carpentry / Fencing / Decks
Ive seen ton of walls like those. The illegals do them like that all the time here.
www.ParkerFenceandDeck.com
curapa is offline
Old 05-31-2009, 11:17 AM   #11
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Why Hardie board and not dens glass? All those seams would have me worried!
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 05-31-2009, 11:53 AM   #12
General Contractor
greg24k's Avatar
In addition, having a skylight above the shower, and the moist air hitting the glass during the cold weather, will turn the air in to a dew which will run down the glass and drip down the walls, the paint will always look like s^%t and most likely the mold will accumulate at the bottom where skylight meets the rock.
I would personally never done that, or explained to the customer and had them sign a waver releasing me from such liability if that happens.
Old 05-31-2009, 12:05 PM   #13
Trade: renovator
Fair enough, but how do you do them, if not like this?
Old 05-31-2009, 12:26 PM   #14
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Setting type compound would be my choice for sure.
Yes those seams are going to be problematic w/ the hardiboard.
Originally Posted by greg24k View Post
In addition, having a skylight above the shower, and the moist air hitting the glass during the cold weather, will turn the air in to a dew which will run down the glass and drip down the walls, the paint will always look like s^%t.
You are correct. I have a skylight over my shower/tub and the dew just rolls down the walls then sits on the cornerbead where it meets the ceiling. I used a good exterior primer then 3 coats of Sherwin Wiiliams exterior Super paint (semi-gloss). Seams to be holding up pretty good since I repaired, textured and painted it 4 years ago. I gotta tell ya, I really like the natural lighting that I get from it.
Sir Mixalot is offline
Old 05-31-2009, 12:36 PM   #15
I've put in a few of these http://www.solatube.net/ customers were very happy with them. Product seems a cheesy but had no problems out of them.
Old 05-31-2009, 01:12 PM   #16
How often does it drop
below zero down there?
neolitic is offline
Old 05-31-2009, 03:09 PM   #17
Never. But I bet it's 150 degrees up in there during the summer. It's like an oven.
Old 05-31-2009, 03:17 PM   #18
It's just that up here,
ib the winter, you get a
cold air shower too!
neolitic is offline
Old 05-31-2009, 09:51 PM   #19
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
Moisture and condensation? How about mounting a high CFM vent fan in the tunnel, say 1/2 to 2/3rds up from the bottom. I would think that would solve that problem.
Heat rises, the steam from the shower with it, it makes the perfect vent location IMO.
JamesKB2 is offline
Old 06-01-2009, 08:36 AM   #20
Trade: renovator
Ya, I'd been thinking that very thing.
Curbless Skylight? Chris G Roofing 9 05-10-2009 08:07 PM
Skylight Tom M Roofing 4 12-23-2008 08:53 AM
Skylight Questions skylight guy Business 5 12-17-2008 10:51 PM
Alternative to drywall for skylight tunnel? bob_cntrctr Drywall 14 12-10-2008 07:54 PM
skylight ruined? go do it General Discussion 6 11-18-2008 11:01 PM
