Walls Poured
Old 02-20-2007, 04:21 PM   #1
jmic's Avatar
Walls Poured
Out of the deep freeze and into warmer weather (40's) gave us a chance to get the foundation poured today. It took 68 cu.yds. of concrete placed in the forms using a concrete pump. 2006 Mack with a Putzmeister concrete boom and pump setup. This rig has a horizontal reach of 103' and according to operator under perfect conditions could put out 265 cu.yds./hr.(mixers would have to be waiting to unload) This outfit which our concrete sub owns 1/2 of has (4) of these trucks . Pretty expensive, the one pictured was $550,000K. They'll strip forms tomorrow, then sub will come in to spray walls, then I'll do drains and get it backfilled.
Joe
jmic is offline
Old 02-20-2007, 04:38 PM   #2
POOLMANinCT's Avatar
Re: Walls Poured
did you order an cal or grease/gel in the mud? very cool you outproduced me today ba a billion %
ray
POOLMANinCT is offline
Old 02-20-2007, 05:23 PM   #3
denick's Avatar
Re: Walls Poured
Good job Joe!
Will you have to take tomorrow off to rest your finger from taking the pictures?
Why did you park the Kobelco on top of the forms like that, were they afraid they would lift?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 02-25-2007, 04:06 PM   #4
Vagitarian
rino1494's Avatar
Send a message via AIM to rino1494
Re: Walls Poured
Joe, don't you put the footer drains in before the forms are set ?
rino1494 is offline
Old 02-26-2007, 11:08 PM   #5
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Re: Walls Poured
I never heard of that. Do you only put your gravel up to the top of the footing? I typically wrap my trench with filter fabric and bring the gravel up 24". Plus the masons are supposed to bond the joint between the footing and the wall with a 45 degree bond. Then the wall and footing are sprayed (and on my jobs, dimple board is applied) then we place filter fabric in the trench and up the walls then put in the gravel, pipe and more gravel.
LNG24 is offline
Old 02-27-2007, 07:20 AM   #6
Vagitarian
rino1494's Avatar
Re: Walls Poured
Around here, after the masons put in the footers, we install the drains and place the stone in the footers level with the top of footer. After the walls are poured and tar'ed, then I lay fabric down and backfill. If we would place more stone and fabric around the foundation, it would raise the price of excavating. Builders like to do the mininum to keep the costs down. Basically, so they can put more money in their pocket.
rino1494 is offline
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Poured Foundations +- phanley Masonry 22 07-22-2007 01:17 AM
Doing block walls instead of a poured foundation Mike Finley Masonry 38 05-16-2006 12:01 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
