Void Space Beneath Slab - Excavation & Site Work Picture Post - Contractor Talk
Old 04-29-2017, 10:26 PM   #1
HerInc's Avatar
Post
Im doing some remodeling inside of a 1924 bungalow in NE Portland. After cutting open the slab to reroute some DWV line it was quickly noticed that there was no soil beneath a 3x3' area. The bottom of the hole is about 18" beneath the slab. There will be a spread footing for a column that is getting relocated right where this void is.
Any suggestions on what I should do to help sturdy things up? im a bit worried about having a footing and lot of load on a spot that is settling.
Im assuming this is caused by settlement due to incomplete consolidation of the soil before pouring the slab.
HerInc is offline
Old 04-30-2017, 12:21 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,646
Re: Void Space Beneath Slab
I would be concerned that there is more of this scenario going on.
May be best to contact a SE or Soils Engineer to evaluate the situation.
Would relieve you of a lot of liability.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Golden view (04-30-2017), greg24k (05-05-2017)
Old 04-30-2017, 12:52 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,874
Was there a leak? Water can move soil.
Golden view is offline
Old 04-30-2017, 09:29 AM   #4
HerInc's Avatar
No leak anywhere that we've found. So it is likely that there is more of this going on beneath other parts of the house?
There are reported issues of water coming up near where one of those drain lines surfaces. Would a poor downspout system cause this kind of erosion?
HerInc is offline
Old 04-30-2017, 09:39 AM   #5
edward trowelhands
Trade: Diplomat
Yes. As would any number of other things. We have a combined storm and sanitary sewer here. Sometimes the rain drains went under the house. You might try to investigate those. If you can't tell where they go, run a hose into each for a while.
It seems pretty localized if the slab stayed flat with such a big void underneath. You could possibly core into the slab in a few other locations to try and determine if the problem extends throughout.
Old 04-30-2017, 01:54 PM   #6
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 194
Drag a length of chain across the floor and you will notice a different sound as it crosses a hollow spot. No need to drill unless you find one of those sounds. The change is quite distinct and is easily noticed. If you try it where you know there is a hollow, you will understand.
jlhaslip is offline
Old 04-30-2017, 06:56 PM   #7
dayexco's Avatar
Rewards Points: 162
k crete as we call it...or an engineer would call it "flowable fill"
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
rino1494 (10-04-2017)
Old 04-30-2017, 09:20 PM   #8
Frog_Legs's Avatar
Trade: Specialty Foundations
Rewards Points: 22
If you have to put a column there, have a soils engineer check it out first. Adding weight to a problem soil is a really bad plan.
FWIW, I made my living for more than 20 years correcting these types of problems.
If you would like to discuss your situation in more detail, shoot me a message and I'll get with you by phone or email. There's often more to it than can easily be covered in a post.
Frog_Legs is offline
Old 05-03-2017, 08:03 PM   #9
HerInc's Avatar
I'm having trouble finding a residential soil engineer, anyone in the Portland area know of someone they've used?
HerInc is offline
Old 05-03-2017, 08:15 PM   #10
HerInc's Avatar
Thanks for your input all.
Yes, the column must go here or else major modifications will need to be made to the design.
Frog_Legs, Have you dealt with issues similar to mine?
I really feel I could just do some heavy soil compaction and then fill this with some low psi concrete and move on, but am also weary to do that and then have 15000 pounds of load cause settlement issues...
I drove a long steel rod (3/4 x 3") about 3 feet down into the soil. I did find some very hard soil that I couldn't penetrate through using a 20 lb sledge hammer.
Feel free to email me at if you prefer to communicate that way.
[email protected]
-Corey
HerInc is offline
Old 05-05-2017, 01:41 AM   #11
kapena's Avatar
Trade: General Building Contractor
Rewards Points: 336
-Corey
The age of the bungalow (1924), along with the considerable soil settlement, seems to indicate that poorly compacted and somewhat deep fill was under that part of the house. The waste plumbing has a bar-code tag on it, so that looks to have just happened. I'm wondering if that plumbing could be relocated enough to not be so directly under the needed footing.
I would get rid of what looks to be some recent fill around the plumbing out of there, and then maybe even remove some more of the older loose fill before doing your "heavy compacting" of the remaining soil for a good spread-footing.
If the plumbing cannot be relocated, I would isolate it from the concrete footing by wrapping it with some neoprene pipe insulation before the pour. That way, some later possible settling will not be as likely to damage the plumbing.
kapena is offline
Slab on top of slab MIKE ANTONETTI Concrete & Paving 26 07-18-2014 06:31 AM
Installing a Door Slab CookeCarpentry Finish Carpentry 62 07-11-2010 07:23 AM
Hack Job: Slab only 1" above grade Doubleoh7 General Discussion 76 03-23-2010 01:06 AM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Another wood subfloor over concrete slab GreenBuilder Carpentry 3 05-08-2008 12:20 PM
