Crusher Run Question - Excavation & Site Work Picture Post - Contractor Talk
Old 10-26-2015, 09:51 PM   #1
MaverickNazgul's Avatar
Trade: Building-Integrated Solar PV
Rewards Points: 4
Smile
Dear all, first post and question please
Situation: I'm currently supervising the construction of a Building-Intergrated PhotoVoltaic (BIPV). The idea is construct a steel structure (just like factories) without the rooftop. The rooftop will then be replaced with solar panels instead. This BIPV is within 100m of the sea. Steel structure is about 80m x 90m x 6m.
Problem: This steel structure is currently being built on seaside soil. Water ponding and heavy machinery entry is a huge problem. Hence, laterite + crusher run is needed (total 450mm height) to support 20 tonne cranes etc. Total area for crusher run is about 0.8acres. But this is really expensive and costs $33,000 USD.
Question: Are there any other cheaper alternatives? THANK YOU.
Tldr; New structure on seaside soil, crusher run cost is a killer. Any alternatives?
MaverickNazgul is offline
Old 10-27-2015, 04:00 AM   #2
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: Crusher Run Question
see if you can get 1 or 2 inch breaker run for a cheaper price
pappagor is offline
The Following User Says Thank You to pappagor For This Useful Post:
MaverickNazgul (10-27-2015)
Old 10-27-2015, 10:01 AM   #3
Rewards Points: 4
hello pappagor, thanks for the suggestion. actually, how do i lay this breaker run?
at the moment im sitting on a quotation for 300mm of Laterite, topped with 150mm of Crusher run. i see that breaker run looks great for soft subsoil.
Old 10-27-2015, 09:18 PM   #4
dayexco's Avatar
Rewards Points: 162
using any fabric?
dayexco is offline
Old 10-27-2015, 09:27 PM   #5
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
What about recycled concrete?
jhark123 is offline
Old 10-27-2015, 09:57 PM   #6
Moxley-Kidwell's Avatar
Trade: Excavation & Asphalt Paving
Rewards Points: 286
Mud/crane mats. Large timbers bolted together that will span sloppy/wet soils. Might take more than one layer but they work wonders. You can rent them here in the us, not sure about in your location.
Moxley-Kidwell is offline
Old 10-28-2015, 04:20 AM   #7
pappagor's Avatar
Rewards Points: 32
dump and spread with a crawler or bobcat.
pappagor is offline
Old 10-31-2015, 06:23 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,001
Cancel the solar baloney, Use the $ saved to pour concrete pipe pilings under the steel columns. Install drainage tile to mean sea level fill over with the crushed rock/concrete. Steel tracked heavy equipment requires embedded rails to protect the concrete surface over time.
Let some silly competitor waste money on the part time power that is solar now. Stick with a 24/7/365 power source. Worst case use your mobile generator set(s) as back up power, if local grid unreliable, A ship/barge mounted power plant would several times cheaper than any pie in the sky solar cell pipe dream.
Ask the solar cell maker if will work after a typhoon?
Fouthgeneration is offline
Old 10-31-2015, 09:00 PM   #9
rustyjames's Avatar
Rewards Points: 1,586
Steel structure 100 meters from the sea, as in salt water? Even if it's hot dipped galvanized good luck!
rustyjames is online now
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 55 01-20-2017 11:48 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
