Welding Truck Headers To Exhaust Pipe..
Old 11-07-2017, 07:42 PM   #1
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,230
I installed a new catalytic converter with a pipe going to the headers on my truck. The connection to the header pipe wasn't the best so I got a coupling about 4 inches long and used high temp epoxy as well. Over time it failed and now I got leak (on the top)
I don't want to spend any more money on a band-aid and have decided to get a welder most likely tig.
But how do I weld the top of the pipe? it's a really tight spot
I guess if I got an ark stick welder I could bend the sticks a little to get up there .
any help would be appreciated thanks.
Haven't welded since high school. the last thing built and welded was my highschool's BBQ 15 years ago.
damn time flys
cedarboarder is offline
Old 11-07-2017, 08:45 PM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,798
Re: Welding Truck Headers To Exhaust Pipe..
Most exhaust guys use mig and have a small gun with a big curve on it to weld exhaust. Usually they just blob wire on the top where you canít see it when working on exhaust attached to a vehicle on a lift
Usually tig is fitted/tacked on the car and taken off and fully welded on the bench when access is tough
Windycity is online now
Old 11-07-2017, 09:56 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
Epoxy does not belong anywhere near an 800+ degree source. You probably also need a flex pipe.
Clarify the word header. Do you mean exhaust manifold? Or something like a Hooker header with a flange on it?
Either way I would weld flanges onto everything, and make it so it comes apart easily with gaskets in between.
Many of the consumer none water cooled TIG welders will also stick weld. My older Lincoln TIG does both. Still a MIG welder is the easiest to learn on, and can do a lot of work, but it will need shielding gas to be worth anything. Plan to spend $800+ for a decent welder.
In reality the simplest solution is to take it to a muffler shop and they will fix you up in less than an hour.
Peter_C is offline
Old 11-07-2017, 09:57 PM   #4
Trade: Workaholic
Yeah guess all I can do is try. removing the headers is a huge pain.
I can't remember how far the wire can go out of the tig gun before it doesn't weld.. If I can get the wire out a bit could help get in there.
Old 11-07-2017, 10:31 PM   #5
Frank Castle's Avatar
Rewards Points: 1,112
Originally Posted by Peter_C View Post
...Clarify the word header. Do you mean exhaust manifold? Or something like a Hooker header with a flange on it?
Either way I would weld flanges onto everything, and make it so it comes apart easily with gaskets in between....
Back on my old '79 I had the Hooker Alumicoat lifetime headers. Yeah right?! That story for another time.
Rusted out from the inside, flange broke off. Barely anything left to weld to. Ended up welding the pipe to the header. Wasn't sorry. Lasted long enough until I could find cheap(free) stock exhaust manifolds.
Adapt, Improvise, Overcome.
Frank Castle is online now
Old 11-08-2017, 07:07 AM   #6
Peter_C's Avatar
Stock manifolds are good for more moderate HP producing motors as you can match port them, but the best part is the cast iron manifolds don't blow gaskets very 10K miles.
Peter_C is offline
Old 11-08-2017, 07:35 AM   #7
rustyjames's Avatar
Rewards Points: 1,548
Sorry, but there is no wire on a tig "torch." A tungsten is used and filler wire added during the welding. I doubt you will ever see a tig process done by a exhaust shop, unless it's for a show car, and stainless at that.
rustyjames is offline
Old 11-08-2017, 12:48 PM   #8
Trade: Workaholic
****, I meant to say Mig with the Wire.
Old 11-09-2017, 04:22 PM   #9
Trade: Workaholic
The welder I'm looking at getting...
https://www.kmstools.com/magnum-130a-mig-welder-133934
anyone ever buy one of these cheap welders?
Not sure where I'm going to get 20amps.. sold my generator last year cause never used it....
Old 11-09-2017, 09:07 PM   #10
Peter_C's Avatar
It is right on par with Harbor Freight
A decent MIG welder will be 220volts and require a 50 amp breaker. My TIG requires a 100 amp breaker Although it will weld 1/4" aluminum.
Have you asked a local muffler shop what they would charge you yet?
Peter_C is offline
Old 11-10-2017, 09:12 PM   #11
Trade: Workaholic
Pretty sure that's my next stop.
Sometimes I go to fix stuff like this and wonder what I'm doing, just pay someone to fix it for me in half hour.
Maybe if I come up with bigger project I can justifie the welder
New to us work truck pinwheel Tools & Equipment 9 06-01-2017 09:55 AM
New truck Clark Bilston Vehicles 2 08-21-2012 10:05 PM
NEWS: Concrete Truck Rolls Down Hillside (with pics) BKFranks Concrete & Paving 5 04-09-2010 01:08 PM
10 Wheeler TRUCK W/ CAT C-12 99 STERLING W/8 40 YARD DUMPSTERS! Paradise Vehicles 0 07-24-2009 01:38 PM
Painted My Truck With a Roller ModernStyle Painting & Finish Work 44 07-21-2007 09:11 PM
