Vertical Welding With 5/32 7018
Old 06-19-2008, 04:55 PM   #21
josh0813's Avatar
Trade: HVAC
Re: Vertical Welding With 5/32 7018
Hey guys, I will probably get kicked out of here, but I have only been welding for a few months, and I switched from sheet metal work to welding exclusively, so I'm technically not a professional contractor. Anyway, on to my comment, which is, even in my limited time as a welder, I know that 7018 is an all-position rod, so the person that said its not is wrong. Also, has anyone ever tried running 7024 vertical? I did just for kicks, and it doesn't really work-AT ALL!
josh0813 is offline
Old 07-19-2008, 06:37 PM   #22
boomup's Avatar
Trade: Ironworker
it will be easier for someone to show you. First use 1/8 for most applications. So many people think that 5/32 is acceptable on 1/4"-3/4". the fact is 5/32 is way to hot and you will have nothing but problems with undercut, grapes, and burnthrough. It takes patience and practice. Best to learn how to do a stringer vert then weave subsequent pass(es). 7018 rod is held at about a 45 degree angle but with time you will adapt to your welding situation. Right now I am burning a 1/8 7018 at about 120 on a small 50% duty cycle 220. It has some dig and took some time to get used to.
boomup is offline
Old 07-19-2008, 06:41 PM   #23
boomup's Avatar
Trade: Ironworker
Ok--it is not an all position rod. There are five positions and 7018 is a 4 position rod. It is Vertical up, overhead, horizontal, and flat. I repeat it is not an all position rod. Go to welding school and take an apprenticeship then you'll learn how to really weld.
boomup is offline
Old 07-19-2008, 07:03 PM   #24
dlcj's Avatar
Trade: home builder carpenter Central Alabama
Originally Posted by flamingskull View Post
Does anybody have tips for running vertical 5/32 7018? I'm currently trying to do it and having problems keeping the molten pool from running down the plate. Any tips or suggestions would be much appreciated.
My solution the the vertical weld is a mig I have done the welding on all my projects (small) for the last 25 years but i have no formal training on the subject of what rods are best and cant remember when i last used a stick welder. I know a mig is not practicle in the field but it is in any size shop with any thickness metal.
You must forgive me i'm board and thought i'd just but in with a smartass answer. ill shutup now
dlcj is offline
Old 08-01-2008, 12:11 AM   #25
HillbillyFab's Avatar
Trade: Metal Fabrication
Every piece of steel welds different. I have good luck welding in a triangle fashion versus a "U" shap in the vertical mode fashion. I know that doesn't make sense without a visual, so I'll try and dig up an example.
HillbillyFab is offline
Old 12-04-2008, 02:02 PM   #26
frogman's Avatar
Trade: welder
skull u usin DC reverse current or AC. with ac u dont have the same manipulation you have with dc reverse. can get alot of arc blow with ac.
also how many amps you using? you weldin thin gauge or heavy plate? for thin gage go with a body rod like 3/32 6012 or 6013, you can down hand it like mig, and it pretty much welds itself all around dummy rod. dont use 6011, thats for weldin root passes on pipe and pressure joints or if ya weldin rusty stuff like on the boats. if yer usin 7018 and havin trouble with the 5/32 drop back to 1/8. 5/32 is for layin on heavy beads and remember vertical welds shouldnt exceed 3 x's time the size of the rod diameter. if yer only puttin a small bead down go with 3/32 at around 95 100 amps. if yer runnin along cable like 100 feet or more you may wanna turn it up a notch to compensate for the amp loss.
as for technique you can whip the root up stright or triangle it, but for 5/32 you need to lay a big root fast so a whip triangle action is needed to melt the parent metal while you pause on the sides for a bit if ya dont whip the middle youll grape er up.
hope this helps.
frogman is offline
Old 12-19-2008, 03:24 PM   #27
JTMcC's Avatar
Trade: Welding & Fabrication Service
No, uphill or downhill is not a position, it's direction of progression.
Two completely different essential variables on any procedure.
While we are at it there are more than 5 welding positions.
JTMcC
JTMcC is offline
Old 12-21-2008, 12:03 PM   #28
rustyjames's Avatar
I was taught in welding school that 5/32 was used for flat and horizontal on heavier weldments. For overhead and vertical we used 1/8 but did multi-pass welds to obtain the proper amount of filler.
rustyjames is offline
Old 12-21-2008, 12:33 PM   #29
JTMcC's Avatar
5/32" is used vertical quite a bit, and works fine if you have heavy enough material.
In fact it's required on the LA City qualification test.
If a guy is having trouble with 5/32" vertical, the best thing he can do is keep practicing with 1/8".
It will come with time, you just have to control a little more heat, and a little bigger puddle.
JTMcC
JTMcC is offline
Old 01-12-2009, 08:49 AM   #30
Balzomedic's Avatar
Trade: Welding
Im wondering what your reasoning is for saying 7018 is not all position. It works quite well in the 6G position when testing for the oil fields. The 6G test one is required to take is making a pipe weld at 45 degrees, which pretty much covers em all. Of course I am by no means the authority but do have some good experience with SMAW. Just curious where you're coming from.
Balzomedic is offline
Old 01-13-2009, 02:00 PM   #31
rustyjames's Avatar
You are correct. The 3rd number on the electrode indicates position and the number 1 being all position. For instance, a 7024 would indicate 2 positions, flat and horizontal. The first two numbers relate to tensile strength and the last is the rod coating.
Old 07-17-2009, 11:10 PM   #32
Darkgod's Avatar
Trade: Welder
Originally Posted by Teetorbilt View Post
Why 7018? 7024 is better for your application plus you can drag the rod.
7024 is for flat and horizontal only...
Darkgod is offline
Old 08-22-2009, 06:00 PM   #33
Wildfire's Avatar
Trade: Commercial / Industrial Repair and Maintenance
Lets see there is flat , horizontal vertical , overhead ,where is this 5th position
Originally Posted by joasis View Post
I guess you are a fabricator in a shop, and not out in the field?
Here is a guide for those that read this:
ELECTRODE IDENTIFICATION
Arc welding electrodes are identified using the A.W.S, (American Welding Society) numbering system and are made in sizes from 1/16 to 5/16 . An example would be a welding rod identified as an 1/8" E6011 electrode.
The electrode is 1/8" in diameter
The "E" stands for arc welding electrode.
Next will be either a 4 or 5 digit number stamped on the electrode. The first two numbers of a 4 digit number and the first 3 digits of a 5 digit number indicate the minimum tensile strength (in thousands of pounds per square inch) of the weld that the rod will produce, stress relieved. Examples would be as follows:
E60xx would have a tensile strength of 60,000 psi E110XX would be 110,000 psi
The next to last digit indicates the position the electrode can be used in.
1. EXX1X is for use in all positions
2. EXX2X is for use in flat and horizontal positions
3. EXX3X is for flat welding
The last two digits together, indicate the type of coating on the electrode and the welding current the electrode can be used with. Such as DC straight, (DC -) DC reverse (DC+) or A.C.
I won't describe the type of coatings of the various electrodes, but will give examples of the type current each will work with.
ELECTRODES AND CURRENTS USED
* EXX10 DC+ (DC reverse or DCRP) electrode positive.
* EXX11 AC or DC- (DC straight or DCSP) electrode negative.
* EXX12 AC or DC-
* EXX13 AC, DC- or DC+
* EXX14 AC, DC- or DC+
* EXX15 DC+
* EXX16 AC or DC+
* EXX18 AC, DC- or DC+
* EXX20 AC ,DC- or DC+
* EXX24 AC, DC- or DC+
* EXX27 AC, DC- or DC+
* EXX28 AC or DC+
I use only 7018 as a general purpose, all position rod.
Wildfire is offline
Old 09-04-2009, 09:16 PM   #34
csv's Avatar
Trade: General
We used 7018 with a 6010 open root for pipe SMAW certs when I was in welding school. In all positions.
csv is offline
Old 09-05-2009, 10:20 AM   #35
rustyjames's Avatar
That would be a 6G position, pipe is grooved and fixed on a 45 degree angle.
Old 10-14-2009, 04:22 PM   #36
JTMcC's Avatar
on plate groove welds:
1G is flat
2G is horizontal
3G is vertical
4G is overhead
on plate fillet welds:
1F is flat
2F is horizontal
3F is vertical
4F is overhead
on pipe or tube:
1G is pipe horizontal, pipe is rotated
2G is pipe fixed vertical
5G is pipe fixed horizontal
6G is pipe fixed at 45 degrees
vertical up or vertical down isn't a position, it's a direction of progression.
JTMcC.
JTMcC is offline
Old 10-14-2009, 05:19 PM   #37
joasis's Avatar
So why are you restating the same point? There are still 3 basic positions, and a multitude of "progressions" if you prefer to split hairs.
You want to try out your skills for real, come take a pipe test in the oil field. Structural welding is a different cat.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 10-14-2009, 06:30 PM   #38
JTMcC's Avatar
Well no there really are more than that, you sdeem to be somewhat confused as to what a position is vs. progression.
We are mainline pipeliners around here, so we're used to inspection that's quite a bit more harsh than on flow lines in the patch.
Thanks anyway.
JTMcC.
JTMcC is offline
Old 10-14-2009, 07:13 PM   #39
joasis's Avatar
Sure...whatever works for you. The last time I tested, it was for 2000 psi pressure vessel. By the old standard, an AWG 9, 1980 or so. You can reinvent the wheel as many times as you like, but the old tried and true welding methods worked for 50 years without sweating progression.
Since this forum deals with construction and not pipelining, then the topic is a little out of scope. I would find it hard to believe that you deal with specifications and pressures found higher then in natural gas processing.
BTW, "flow lines" are the lines that are coupled and placed between a wellhead and a tank battery....I have yet to see one welded. Mainline compressor fields can have operating pressures exceeding 1500 psi continuously.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 11-07-2009, 11:50 AM   #40
JTMcC's Avatar
It's not spliting hairs, it's presenting a little info that might help clarify the topic for people who don't work in the welding world every day.
And we first took a tour thru the oil patch many years ago and have made quite a few welds in that environment over the decades.
JTMcC.
JTMcC is offline
New OSHA standard OsNap Health & Safety 8 01-08-2010 09:19 PM
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 06:47 PM
Vertical Cedar Channel Rustic.. RISENRUN Carpentry 2 06-20-2007 12:46 PM
Which welding course? Robie General Discussion 17 05-05-2007 01:13 AM
Question - At what distance is welding still dangerous to eyesight CGofMP Health & Safety 2 02-18-2006 11:30 PM
