Steel I-Beam Spanning
Old 11-26-2008, 09:02 PM   #1
wfd's Avatar
Trade: Construction
I want to span 26' using a 10'' I-beam already in existence. The I -beams presently in place are 2 pieces, 13' each with a 3'' gap in between. I would like to remove a center post which supports both beams. I would like to know if I can plate the beam on both sides and if you could tell me what thickness of the plating should be that would support a 2-story house above the steel beams. The house does not have a trussed roof.
wfd is offline
Old 11-26-2008, 09:04 PM   #2
genecarp's Avatar
Re: Steel I-Beam Spanning
Who wants to start
genecarp is offline
Old 11-26-2008, 09:09 PM   #3
Thom
thom's Avatar
Those will work just fine. They will work better if you put a very heavy masonry load on top of them to minimize the bounce effect. Personally, I'd tack weld the beams together and do with no posts. You should be able to super glue the beams to the foundation walls and eliminate the posts.
As for the plating, just use the normal plates you find at Dennys. If you eat your breakfast there regularly, you should be able to smuggle enough out to do the whole job in a few weeks.
Don't forget to take a place setting of silverware. If the glue doesn't hold you'll be forked.
thom is offline
Old 11-26-2008, 09:29 PM   #4
joasis's Avatar
Before the boys smell blood in the water, tell us you are not serious?
So you understand clearly, no one with the experience to answer this question would do so, on an internet forum. Next is this: What you are describing would require an engineer, on site, before to spec it, and after to inspect it, or you couldn't buy enough liability insurance to cover your ass.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
Old 11-26-2008, 09:34 PM   #5
genecarp's Avatar
[quote=joasis;543893]Before the boys smell blood in the water,
Might be to late
genecarp is offline
Old 11-26-2008, 09:39 PM   #6
Thom
thom's Avatar
Come on guys. 1st post, trade: construction. Obviously the guys a homeowner not a builder. That means he walks on water and floats on air. He can hang the moon from a sky hook and piss the pacific ocean all before lunch. Of course those beams will work, why engineer it when you can ask someone on the internet?
thom is offline
The Following User Says Thank You to thom For This Useful Post:
skyhook (09-24-2010)
Old 11-26-2008, 09:45 PM   #7
Sean
SLSTech's Avatar
Hey, I spent last night in a Holiday Express, so I am perfectly qualified to answer this - of course you can, just don't cheap out - Gold Plating all the way
Do it wrong though & it will be a real expensive headache
Hire a Structural Engineer or a contractor smart enough to hire a SE - PERIOD
SLSTech is offline
Old 11-27-2008, 10:41 AM   #8
i want to span 26' using a 10'' i-beam already in existence. The i -beams presently in place are 2 pieces, 13' each with a 3'' gap in between. I would like to remove a center post which supports both beams. I would like to know if i can plate the beam on both sides and if you could tell me what thickness of the plating should be that would support a 2-story house above the steel beams. The house does not have a trussed roof.
no!
Happy Thanksgiving
neolitic is offline
Old 12-03-2008, 10:49 PM   #9
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
Man, as a PE, this my bread and butter. I do calcs for this sort of thing daily. But I get paid a lot of money to push my pencil and tap my calculator.
Whether you should eliminate the column and leave the beams alone or not should be obvious. The answer is don't even think about it. "Plating both sides" and doing nothing for the flanges isn't a sufficient splice, even if the beam was big enough to span 26 feet (and there's no way to tell with the info you provided). A vertical-only splice only offers strength in shear, not moment.
I've eliminated columns before, and I've properly spliced beams, boxed beams out, etc, but again, my license is my license, and I'm insured and I know what I'm doing. Please call a local PE.
Aggie67 is offline
Old 01-20-2009, 06:23 PM   #10
enforcer's Avatar
Trade: windows-siding
i love I-Beam for vinyl window frames.
enforcer is offline
Old 01-20-2009, 06:52 PM   #11
Pompass Ass
bwalley's Avatar
Get some 2x6's, put them on each side of the beam and on the top and bottom of it and wrap it with duct tape, I like the Gorilla brand myself.
on the first wrap make sure you overlap the tape 50% and go clockwise, then when you get to the end, start there and go counter clockwise, then keep going back and forth, the more plies, the stronegr it will be.
You could also use JB Weld 1st, although code doesn't require it.
Then when you are done call the building inspector for your final, he should be impressed if you do it properly.
bwalley is offline
Old 09-18-2010, 10:53 AM   #12
wvtbred's Avatar
Trade: building owner
Looking to renovate a warehouse. Have two 25,000 sf sections that have three 8" supports down the middle. Potential client wants these supports removed to put hockey rinks in.
Any ideas if it's possible and what I am looking at cost wise? All roof supports are steel Ibeam.
Thanks
wvtbred is offline
Old 09-18-2010, 11:08 AM   #13
User60231's Avatar
I know its been a long time since this was posted, but man that is some funny stuff! I sure needed a good gut wrench chuckle.
Thanks for posting it Thom!
and thanks for bumping this up wvtbred!
Hopefully someone (perhaps even good ole Thom) will be along shortly to properly address your question.
User60231 is offline
Old 09-24-2010, 01:19 PM   #14
CJKarl's Avatar
Trade: Masonry
[QUOTE=genecarp;543898]
Might be to late
Hey, what are you doing over here? You weld AND lay brick? Very talented.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 09-24-2010, 01:20 PM   #15
CJKarl's Avatar
Trade: Masonry
Thanks
Leave them in, it will make the game that much more exciting.
CJKarl is offline
The Following User Says Thank You to CJKarl For This Useful Post:
CookeCarpentry (09-24-2010)
Old 09-24-2010, 02:29 PM   #16
Anti-wingnut's Avatar
Thanks
You're not serious are you? You read all the posts in this thread, especially Aggies well reasoned response, and you are still asking a highly technical engineering question on the web?
What do you expect, yes it is possible, and it should cost about $1000? Come on, get some brains in your head.
Anti-wingnut is offline
Old 09-24-2010, 03:29 PM   #17
Super B
skyhook's Avatar
I'd have to see it first, but I'm guessing NFW.
Thanks
Sure, I can have that done before lunch. Probably gonna run about tree fiddy (million)
skyhook is offline
Steel Beam tznuk Welding & Steel Trades 8 11-26-2008 07:20 AM
Spanning Steel question y0ud Construction 3 10-31-2008 11:38 AM
Steel Beam Question MohaimenK General Discussion 19 09-25-2008 07:59 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Steel beam replacement BHI Carpentry 17 02-28-2008 12:03 AM
