Steel Beam
Old 11-25-2008, 07:36 PM   #1
tznuk's Avatar
Trade: Remodeling, Barns, Garages, New Home Construction
Steel Beam
I need to get a steel beam to span 35' and it will have two other steel beams coming off of it spanning 12' each perpendicular to the larger beam, they will be placed at 1/3 and 2/3 of the length in order to support a roof with it. It will be a light roof and not needing to support a lot but I do need it to span this without drooping at all. Please let me know. I know that normally I would get an engineer to step in on this but it is just for a porch coming off of a garage.
tznuk is offline
Old 11-25-2008, 07:45 PM   #2
joasis's Avatar
Re: Steel Beam
How much will an engineer charge you to spec this structure? No one is going to give you a spec on a forum for a potential lawsuit.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
Old 11-25-2008, 07:49 PM   #3
Re: Steel Beam
Well, if it just a light roof........
neolitic is offline
Old 11-25-2008, 09:41 PM   #4
buckeyeso2's Avatar
Trade: carpentry
Re: Steel Beam
and just for a porch......
buckeyeso2 is offline
Old 11-25-2008, 09:49 PM   #5
Professional Instigator
rbsremodeling's Avatar
Re: Steel Beam
what the **** are you asking?? Is there a question in there?
rbsremodeling is offline
Old 11-25-2008, 10:00 PM   #6
painter213's Avatar
Trade: Coatings consultant and Inspector
Send a message via AIM to painter213
Re: Steel Beam
Go go a local Fab Shop. They should be able to help you out. They might have a licensed PE or have one that does work for them. This beam will have to have gussets and stiffiners applied. The weight of the beam is going to be heavy enough, add in the roof line over 35' and she's going to be heavy. I would not try this build without a sign off of a PE on the drawing.
Benny Abbott
Abbott Consulting and Coating Inspections
E-Mail: babbott@abbottcoatinginspections.com
Phone: (205-717-0292)
painter213 is online now
Old 11-26-2008, 07:18 AM   #7
tznuk's Avatar
Re: Steel Beam
I am asking what kind of beam I would need for this.
tznuk is offline
Old 11-26-2008, 07:19 AM   #8
tznuk's Avatar
Re: Steel Beam
I am referring to there will be no plywood, no underlayment, and it will be corrugated steel (like on an old barn) so yes I know it sounds funny but it is a light roof.
tznuk is offline
Old 11-26-2008, 07:20 AM   #9
tznuk's Avatar
Re: Steel Beam
Great Idea, thanks.
tznuk is offline
Steel Beam Question MohaimenK General Discussion 19 09-25-2008 07:59 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Steel beam replacement BHI Carpentry 17 02-28-2008 12:03 AM
Steel I beam capacity IHdonnie Construction 13 10-21-2006 09:42 PM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 06:45 PM
