Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Welding & Steel Trades
Old 07-15-2009, 05:03 PM   #1
Fitter
Trade: pipefitter
Odd angle fitting from a 45 elbow
Hello, I'm fairly new to pipefitting. I've just passed my NCCER cert. test. But I've still got alot to learn. Today I was asked how to figure out the ordinates and cuts to make a 29.6 degree angle out of an existing 45.
The basic layout is not a problem, it's simple math. The trouble I'm having is figuring out the best way to find my centerline on each side of the elbow. I have a few ideas and theories but figured I'd put the question out here and see if one of the old veteran pipefitters may have a simplified method.
FYI I'm dealing with schd 40, 36" cs pipe/fittings
Thank you in advance for any ideas.
Spooker is offline   Reply With Quote
Old 10-14-2009, 02:55 PM   #2
Trade: Welding & Fabrication Service
I know this is an old question, but if I'm reading you right you just need to quarter the pipe?
Level the fitting, find top dead center with a center finder. You can quarter the pipe off that mark with ticker tape.
Or if the angle will allow just use the center finder.
JTMcC.
JTMcC is offline   Reply With Quote
Angle Iron to Block Tommy C Masonry 37 04-12-2009 09:42 AM
How do I cope for an obtuse angle? karma_carpentry Finish Carpentry 9 01-10-2009 08:40 AM
Tape tech 3" angle head problem. Help! dryrocker27 Drywall 16 12-10-2007 11:49 PM
Best way to attach angle to this? sandyman720 Masonry 6 09-25-2007 07:17 PM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 04:20 AM
