Galv Guardrail/handrail
Old 08-13-2013, 09:56 AM   #1
Fabricator
kbenz's Avatar
Trade: fabricator
Rewards Points: 147
This co wants me to bid on these handrails/guardrails. 2" pipe, roughly 210' feet. usually I would build this onsite. but they are wanting it galvanized. I have never dealt with galvanized rails before. how would you build this in shop have it galvanized and install it?
galv guardrail/handrail-1.jpg
kbenz is offline
Old 08-13-2013, 12:57 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,672
Re: Galv Guardrail/handrail
Contact your galvanizer and ask how big a section they can handle and any specifics they may want to make the process easier.
You will have to cold galvanize the joints at installation.
Watch your transportation costs & lead time.
Perhaps write an RFI just to check that this process is ok.
griz is offline
Old 08-13-2013, 03:03 PM   #3
rustyjames's Avatar
Rewards Points: 1,548
If I didn't have shop drawings to work with, I'd take some very careful field measurements, or build it and section it out in the field, then send it out to get galvanized. Another big consideration would be how it's going to be mounted.
rustyjames is offline
Old 08-13-2013, 04:16 PM   #4
Fabricator
kbenz's Avatar
Trade: fabricator
Rewards Points: 147
The local galvanizer said he could do 42'
I will look into the cold galvanize process. (He suggested a slip fitting)
What is an RFI?
Thanks
kbenz is offline
Old 08-13-2013, 04:19 PM   #5
Fabricator
kbenz's Avatar
Trade: fabricator
Rewards Points: 147
Not sure yet as to what drawings will be available. The 30' radius is what really worries me about not building on site.
I will have to core drill to mount them
kbenz is offline
Old 08-13-2013, 05:07 PM   #6
rustyjames's Avatar
RFI= request further information. I agree with your thoughts on that radius too. I also think slip connections would be the way to go if it's not going to get painted, cold zinc joints don't look too good.
As far as bidding it with the added cost of the HDG, the galvanizer should be able to give you a close number with a clear description of the metal work. I've gotten pricing in the past for W sections and the like just by giving them the total weight. Not sure about hand rails though.
Old 08-13-2013, 05:12 PM   #7
Fabricator
kbenz's Avatar
Trade: fabricator
Rewards Points: 147
He said he went strictly by weight. Gave me a run down of the per weight costs. the more weight the less per pound. Seemed like a good guy. he's the one that suggested slip fittings
kbenz is offline
Old 08-15-2013, 08:20 PM   #8
DPDT, Momentarily on
App-ironworks's Avatar
Trade: Metal Fabricating/Welding/Ornamental Metal
Rewards Points: 1,024
Sounds like you're on track. Remember to ask your galvanizer about vent holes if you're building with pipe or tube.
Whatever you do, do well.
-Brian-
www.appironworks.com
App-ironworks is offline
Old 08-15-2013, 09:12 PM   #9
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,112
Is the galvanizing the finished surface?
I have done stuff like this before but we would build it in place then clean the welds and spray with a cold galvanized spray then prime and paint.
What am I missing?
Andy.
P.S. I should have said etch, prime and paint.
ScipioAfricanus is offline
Old 08-15-2013, 09:15 PM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 890
I would ask if anodized aluminum is suitable and order it up from my supplier....galv seems so rough...
overanalyze is offline
Old 08-15-2013, 09:29 PM   #11
rustyjames's Avatar
It would no doubt be suitable, and beautiful, but it would cost a whole lot more.
Old 08-15-2013, 09:35 PM   #12
Always Learning
Rewards Points: 890
I am spoiled because we have this company in our back yard...
http://www.superioraluminum.com/aluminum-railings/
They do great work and I think it is reasonable pricing. I will say I have no idea how it compares to Galv pipe....
Old 12-28-2014, 02:41 PM   #13
HARD STEEL's Avatar
Trade: Ironwoker
Rewards Points: 30
What is an RFI?
Thanks
( RFI ) Request Further Information
HARD STEEL is offline
Old 01-13-2015, 11:36 AM   #14
gfourth's Avatar
Trade: Structural & Misc. Steel
Rewards Points: 164
What am I missing?
Andy.
This is always the approved method for touching up field welds on hot dip galvanized steel. In my area at least.
Yes, this is mandatory and also takes more time in the shop. Read ASTM A385 for how vent holes should be placed.
I will typically field measure the rail and mark the post holes on the ground at the same time (whether I am drilling or not), and keep a nice clean set of shop drawings. I build all the rail in the shop in the largest sections possible (my galvanizer has a 21' tank), and assemble/install in the field. Cold galv the field joints per the above.
gfourth is offline
Old 01-13-2015, 11:43 AM   #15
gfourth's Avatar
Rewards Points: 164
I would like to add... NEVER agree to field measure/get going on the rail until ALL the pertinent concrete is poured. I never go off of form work or layouts on walls. The pour always varies, enough to throw off your pitches and heights.
gfourth is offline
Old 01-15-2015, 02:16 PM   #16
EXO's Avatar
Trade: Metals
Rewards Points: 114
I think most of this has been covered by others already, but
Build in sections in shop-whatever size you and your galv sub can best handle, get them HDG, bolt/weld in field, spray galv the field welded sections. If you are core drilling and epoxying the posts then you don't need to wait until the concrete is complete...
EXO is offline
Window broken and 8d galv. spikes fastening aluminum j woodWC&R Windows, Siding and Doors 0 04-29-2011 10:11 PM
In wall Security , 14 ga Galv. Sheeting plazaman Commercial Construction 33 12-21-2009 09:18 PM
Galvanized Copper ABS CPVC pscinteriors Remodeling 2 05-27-2008 06:58 AM
Galvanized Compression Fittings ? We Fix Houses Plumbing 25 11-10-2007 07:53 PM
Brass or Galv Nipple Stubs? Ron The Plumber Plumbing 5 02-02-2007 05:33 PM
